1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: About MEDM
To: Ned Arnold <[email protected]>
Cc: EPICS Tech Talk <[email protected]>, Yasemin Barutçu <[email protected]>
Date: Tue, 9 Apr 2013 09:08:30 -0400
As to changing the limits on the monitor objects, MEDM gets those from the HOPR and LOPR fields for the process variable in the object.
James
On Tue, Apr 9, 2013 at 8:33 AM, Ned Arnold <[email protected]> wrote:
Hello Yasemin -
MEDM uses the color "white" to indicate it cannot connect to the PV that is specified in the widget.  You must have an IOC running which has that PV in its database.
You might want to start with the examples described in the Application Developers Guide.
   Ned
To: [email protected]
Sent: Tuesday, April 9, 2013 1:13:59 AM
Subject: About MEDM
Hello,
O.S. : Opensuse
Epics base version : 3.14.12.3
Medm version : 3.1.7
I started to learn MEDM and I just draw something on the screen.
My questions are;
1. White screen displayed instead of the monitor objects when using execute mode. As you can see below image:
Satır içi resim 1
2. I can't change the PV Limits of the monitor objects. But on terminal I don't get any error about it. Just bip sound come to me.
Yasemin Barutçu
About MEDM Yasemin Barutçu
Re: About MEDM Ned Arnold
Prev: Re: About MEDM Ned Arnold
Next: RE: Newport Piezo USB Controllers Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Next: RE: About MEDM Mark Rivers
ANJ, 20 Apr 2015 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
