Hello CA Experts
I have a strange problem with an IOC runnign EPICS base 3.14.8. Half an hour
ago, it suddenly started issuing error messages like
../online_notify.c: CA beacon (send to "193.149.12.255:5065") error was
"S_errno_ENOBUFS"
which I now get periodically (every few seconds).
Now, what is funny is that the IOC does not have any records on it. I have a
very similar IOC in the same network (same base version) that /does/ have
records on it and which does /not/ issue these messages.
There is probably some rogue CA client on the network that broadcasts name
resolution requests with a (too) high frequency (this is our development
network, not operation, fortunately), but I have not yet managed to find out
its IP address.
"casr 2" says
Channel Access Server V4.11
No clients connected.
UDP Server:
UDP 193.149.12.6:38238(): User="", V4.11, 0 Channels, Priority=0
Task Id=0x1d31698, Socket FD
Secs since last send 2853.75, Secs since last receive 1550.10
Unprocessed request bytes, Undelivered response bytes=0
State=up
168 bytes allocated
There are currently 1176 bytes on the server's free list
7 client(s), 0 channel(s), 0 event(s) (monitors) 0 putNotify(s)
0 small buffers (16384 bytes ea), and 0 jumbo buffers (16408 bytes ea)
The server's resource id conversion table:
Bucket entries in use = 0 bytes in use = 16404
Bucket entries/hash id - mean = 0.000000 std dev = 0.000000 max = 0
The server's array size limit is 16408 bytes max
Channel Access Address List
193.149.12.255:5065
This is strange in and of itself, since it first says "No clients connected"
(which I expected, since there are no records) and then later "7
client(s),..." which I find disturbing.
So, if anyone has an idea what might be going on here I'd be glad for an
explanation. BTW, I restarted the IOC which silences the error messages for
some time (a few minutes, maybe) after which they start again.
How do I find rogue CA clients (if that causes the problem at all, maybe
something else is wrong)? Could network problems cause this? Is there maybe a
known bug in 3.14.8 that could explain this?
Cheers
Ben Franksen
() ascii ribbon campaign - against html e-mail
/\ www.asciiribbon.org - against proprietary attachm€nts
signature.asc
Description: This is a digitally signed message part.
- Re: CA beacon / ENOBUFS Andrew Johnson
RE: asynAddress, asynPortDriver maxAddr, and addr in setXXXParam Mark Rivers
Re: Fault Report and Tracking System enquiry? J. Lewis Muir
<2013>
RE: asynAddress, asynPortDriver maxAddr, and addr in setXXXParam Emmanuel Mayssat
<2013>
