1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: RE: asynAddress, asynPortDriver maxAddr, and addr in setXXXParam
To: "'Emmanuel Mayssat'" <[email protected]>, "[email protected]" <[email protected]>
Date: Fri, 5 Apr 2013 00:28:58 +0000
> My understanding of maxAddr is that the parameter library is an array of param lists x maxAddr
That is correct.
> So if I set the asynAddress to a value between 0 and maxAddr, I should be able to 'browse' the whole parameter library.
That is correct.
Did you set the ASYN_MULTIDEVICE bit in the “asynFlags” parameter in your call to the asynPortDriver base class constructor?
From: [email protected] [mailto:[email protected]] On Behalf Of Emmanuel Mayssat
Sent: Thursday, April 04, 2013 7:14 PM
To: [email protected]
Subject: asynAddress, asynPortDriver maxAddr, and addr in setXXXParam
In other words, 2 records with the INP field as
 field(INP,  "@asyn(asynPort,1,$(asynTimeout))REASON")    <-- asynAddress = 1
and
 field(INP,  "@asyn(asynPort,2,$(asynTimeout))REASON")
and with
 field(PINI, "1")
should immediately read different values.
A quick test with
/* setDoubleParam(0, P_Reason, 1.0) */
setDoubleParam(1, P_Reason, 2.0)
setDoubleParam(2, P_Reason, 3.0)
in asynPortDriver constructor and after firing up the ioc, both of the records want to read the address 0.
Are those addresses related? What am i missing?
Emmanuel
RE: asynAddress, asynPortDriver maxAddr, and addr in setXXXParam Mark Rivers
asynAddress, asynPortDriver maxAddr, and addr in setXXXParam Emmanuel Mayssat
Prev: asynAddress, asynPortDriver maxAddr, and addr in setXXXParam Emmanuel Mayssat
Next: CA beacon / ENOBUFS Benjamin Franksen
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Next: RE: asynAddress, asynPortDriver maxAddr, and addr in setXXXParam Mark Rivers
ANJ, 20 Apr 2015 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
