1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: alarm handler silence one hour button
To: Janet Anderson <[email protected]>
Cc: [email protected]
Date: Tue, 26 Mar 2013 15:45:10 -0400
Either that or adding in a similar possibility in the alarm handler
config file would be great!  Personally I'd prefer adding something in
the config file to simplify starting up the alarm handler, but
whichever you deem best would be fine.  Either would work.
James
On Tue, Mar 26, 2013 at 3:24 PM, Janet Anderson <[email protected]> wrote:
> Hi James,
> I am now making some changes to the alarm handler so I will look into making
> this change. How about specifying the silence minutes as an alh command line
> option? The message next to the silence button could contain the command
> line minutes with the default (no command line option) message "Silence 60
> minutes". We also need a command line option specification, e.g.
> "-silenceMinutes 10".
> Janet
> On 03/26/2013 01:43 PM, James F Ross wrote:
>> Hello everyone,
>> I'm not sure if this is a standard feature on the epics alarm handler
>> in general, or if it is something that is addable, but the alarm
>> handler at STAR has a button that allows you to silence the alarm
>> handler for one hour.  I was wondering, would it be possible to change
>> this to, say, silence for 10 minutes?  That would be much more useful
>> to us.  I can't find anything on changing this in the manual, but
>> perhaps there is something I can add to the configuration file?
>> Thanks very much!
>> James
alarm handler silence one hour button James F Ross
Re: alarm handler silence one hour button Janet Anderson
Prev: Re: alarm handler silence one hour button Janet Anderson
Next: Fix length of exponent in Streamdevice %E Florian Feldbauer
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
ANJ, 20 Apr 2015 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
