1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: FW: MEDM objects turn white when ioc running correctly
To: "Tech Talk ([email protected])" <[email protected]>
Date: Mon, 25 Mar 2013 18:53:49 +0000
Sent: Monday, March 25, 2013 8:44 AM
To: '
张德敏'
Subject: RE: MEDM objects turn white when ioc running correctly
Here are some fault isolation steps.
o make certain that you can ping your soft IOC from where MEDM runs.
o make certain that the linux firewall for your soft ioc grants access to the CA server port numbers (typical 5064)
o make certain that MEDM and the soft IOC are on the same subnet, If not you may need to set the EPICS_CA_ADDR_LIST
o Note also that currently  when two soft IOCs run on the same host that it is difficult to reach both of them with UDP unicast based search messages (the default UDP broadcast based configuration works fine)
Jeff
From: [email protected] [mailto:[email protected]] On Behalf Of ???
Sent: Monday, March 25, 2013 3:24 AM
To: tech-talk
Subject: MEDM objects turn white when ioc running correctly
I have built a softIOC on my Linux rhel5(base3.14.9-prel,ASYN4-8,Stream Device-2-3). When running the application, it works well(using "dbpf" can set channel value, and the device can get the setting). But when executing MEDM, the objects turn white. It is very strange(the control channel of object in MEDM and the record in db file have the same name ).
MEDM objects turn white when ioc running correctly 张德敏
Prev: FW: PMAC austen.rose
Next: RE: EPICS for personal safety system Bryce Karnaghan
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: RE: MEDM objects turn white when ioc running correctly Mark Rivers
Next: MAXV card with firmware version 1.42 austen.rose
ANJ, 20 Apr 2015 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
