Does the command "caget" from EPICS base work to read the value of the PVs on the same computer running medm?
If not, then your problem may be a firewall. Make sure "iptables" is either disabled or configured to allow TCP and UDP on ports 5064 and 5065.
From: [email protected] [[email protected]] on behalf of 张德敏 [[email protected]]
Sent: Monday, March 25, 2013 4:24 AM
To: tech-talk
Subject: MEDM objects turn white when ioc running correctly
I have built a softIOC on my Linux rhel5(base3.14.9-prel,ASYN4-8,Stream Device-2-3). When running the application, it works well(using "dbpf" can set channel value, and the device can get the setting). But when executing MEDM, the objects turn white. It is very strange(the control channel of object in MEDM and the record in db file have the same name ).
- MEDM objects turn white when ioc running correctly 张德敏
MAXV card with firmware version 1.42 austen.rose
PMAC Gaudiello, Phillip
<2013>
FW: MEDM objects turn white when ioc running correctly Hill, Jeff
<2013>
