1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: MEDM objects turn white when ioc running correctly
To: tech-talk <[email protected]>
Date: Mon, 25 Mar 2013 17:24:26 +0800 (CST)
I have built a softIOC on my Linux rhel5(base3.14.9-prel,ASYN4-8,Stream Device-2-3). When running the application, it works well(using "dbpf" can set channel value, and the device can get the setting). But when executing MEDM, the objects turn white. It is very strange(the control channel of object in MEDM and the record in db file have the same name ).
RE: MEDM objects turn white when ioc running correctly Mark Rivers
FW: MEDM objects turn white when ioc running correctly Hill, Jeff
Prev: Re: EPICS for personal safety system Dudley, David
Next: MAXV card with firmware version 1.42 austen.rose
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: RE: EPICS for personal safety system Mark Rivers
Next: RE: MEDM objects turn white when ioc running correctly Mark Rivers
ANJ, 20 Apr 2015 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
