1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: EPICS for personal safety system
Date: Sun, 24 Mar 2013 14:21:16 +0000
In the case of BNL's NSLS-II, in order to meet the safety requirements, EPICS and the PLC's in the PPS (Personnel Protection System) have no direct access between them.
There is an intermediate PLC with 2 network interfaces that EPICS has complete access to, and the PPS PLC's have write access to.
 Nothing can directly access the PLC's in the PPS system, and it writes status information into, and reads commands from the interface PLC.
That prevents EPICS from sending a command that might compromise the PPS, as well as access from anything else on the controls network causing the PPS PLC's to be compromised.
Later-
David
On Mar 24, 2013, at 5:20 AM, Morteza Mansouri <[email protected]> wrote:
Subject:
To:
Hello everyone,
We are planning to build a monitoring system for our PSS (personal safety system) in SESAME based on EPICS.
I am looking for some advice if it is recommended that the IOC has writing permission to PSS PLCs or it should be the case of the IOC only reading from PSS PLC.
Many thanks for your help in advance.
Morteza Mansouri
PSS (Personal Safety System) Engineer
SESAME (Synchrotron-light for Experimental Science and Applications in the Middle East)
P.O. Box 7, Allan 19252, Jordan
EPICS for personal safety system Morteza Mansouri
Prev: EPICS for personal safety system Morteza Mansouri
Next: Re: EPICS for personal safety system Dudley, David
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
ANJ, 20 Apr 2015 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
