No, that is not correct. Here is the correct sequence/comments
1) drvAsynIPPortConfigure() with noAutoConnect=1;
Why are you using noAutoConnect=1? If you have already created the server then you can use the default noAutoConnect=0.
2) pasynCommonSyncIO->connect(); get type 1 connection with common pasynUser
2a) pasynCommonSyncIO->connectDevice(); If you used noAutoConnect=1 you need this step, otherwise skip it
3) pasynOctetSyncIO->connect(); get type 1 connection with octet pasynUser
4) pasynOctetSyncIO->read()/write(); exchange data
5) pasynOctetSyncIO->disconnect(); release type 1 connection with octet pasynUser
6) pasynCommonSyncIO->disconnectDevice(); release type 2 connection with common pasynUser
7) pasynCommonSyncIO->disconnect(); release type 1 connection with common pasynUser
Note that the pasynXXXSyncIO->disconnect functions not only release the type 1 connection, they also call pasynManager->freeAsynUser. This means that your pasynUser no longer points to a valid pasynUser structure, so it's a good idea to set the pointer to 0.
-----Original Message-----
From: [email protected] [mailto:[email protected]] On Behalf Of Sinisa Veseli
Sent: Wednesday, March 20, 2013 1:31 PM
To: [email protected]
Subject: Re: drvAsynIPPort question
Mark,
Thanks for the response and clarifications. So, if I understood things,
the following is a proper process of establishing/using/destroying TCP
connection using asyn IP driver:
2) pasynCommonSyncIO->connect(); get type 2 connection with common pasynUser
pasynUser
6) pasynCommonSyncIO->disconnect(); release type 2 connection with
common pasynUser
Is the above correct?
It looks like drvAsynIPPortConfigure() does call
pasynManager()->connectDevice(), which would seem like I would end up
with 2 type 1 connections, which makes me a bit suspicious.
Thanks again,
Sinisa
On 03/20/2013 12:43 PM, Mark Rivers wrote:
>> I see that connection is closed in asynCommonDisconnect() method (file
>> interfaces/asynOctetSyncIO.c), but it isn't quite clear to me how this
>> method would get called (pasynOctetSyncIO->disconnect() does not seem to
>> do it).
> The method you need to call is pasynCommonSyncIO->disconnectDevice(pasynUser)
> Note that the pasynUser that you pass in this call must be created with pasynCommonSyncIO->connect(), and it must NOT be the pasynUser that you created with pasynOctetSyncIO->connect(). That is a common mistake.
> Note that the asyn unfortunately has two meanings of the term "connect".
> 1) The first meaning is to connect a pasynUser to an asyn port driver and address.
> 2) The second to connect the asyn port driver to the underlying device, in your case a TCP socket.
> pasynManager->connectDevice does the type 1 connection.
> pasynCommon->connect does the type 2 connection.
> To make things even more confusing the terms "connect" and "connectDevice" are reversed in the asynXXXSyncIO functions.
> The asynXXXSyncIO functions pasynXXXSyncIO->connect do a type 1 connection. This really should have been called "connectDevice" to make it consistent with the pasynManager function.
> pasynCommonSyncIO->connect does a type 1 connection, to be consistent with all of the other asynXXXSyncIO methods. pasynCommonSyncIO->connectDevice does a type 2 connection, while this should have been called "connect" to be consistent with the pasynCommon method.
> Unfortunately we need to live with these names, it's too late to change them now.
> Mark
> Sent: Wednesday, March 20, 2013 12:02 PM
> Subject: drvAsynIPPort question
> Hi,
> Does anyone know what is the proper way to destroy tcp socket created
> via drvAsynIPPortConfigure?
> My test client and server use drvAsynIPPortConfigure and
> drvAsynIPServerPortConfigure from asyn 4-18, and I can connect and
> exchange data between the two. However, no matter what I try, I am not
> able to destroy the client socket properly.
> do it).
> I looked through marCCD.cpp in area detector module (Tim Madden kindly
> pointed that out as an example), but I only saw
> pasynOctetSyncIO->connect() being called.
> In any case, I would appreciate any pointers, and sorry if I'm missing
> something obvious...
> Thanks,
> Sinisa
Sinisa Veseli
Software Services Group
APS Engineering Support Division
Argonne National Laboratory
[email protected]
(630)252-9182
- Re: drvAsynIPPort question Sinisa Veseli
- drvAsynIPPort question Sinisa Veseli
- RE: drvAsynIPPort question Mark Rivers
<2013>
<2013>
