1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: delay before alarm on alarm handler
To: [email protected]
Date: Wed, 20 Mar 2013 12:02:40 -0600
Hi James,
On 2013-03-20 James F Ross wrote:
> Does anyone know how to build in a delay for a process variable so
> that it won't alarm unless the value is in the alarm range for a
> setable period of time?  For instance, I'd like to set a particular
> variable so that it will alarm only if the value is below the LOW
> alarm setting for one second or longer.  Is this doable either through
> the alarm handler or the database file or would I have to go into the
> source code and manually program in a delay?
ALH can do this itself using $ALARMCOUNTFILTER, see
http://www.aps.anl.gov/epics/EpicsDocumentation/ExtensionsManuals/AlarmHandler/alhUserGuide-1.2.15/ALHUserGuide.html#6_3_12
In 3.15 you'll be able to configure the standard input record types to filter
alarms too, but for now the solutions available to you are either to use
ALH's $ALARMCOUNTFILTER or to do something a lot more complicated in a
database or an snl program.
- Andrew
There is no such thing as a free lunch.  When invited for lunch,
it is best to check if you are there to eat, or to be eaten.
-- Clive Robinson
Re: delay before alarm on alarm handler James F Ross
Prev: RE: drvAsynIPPort question Mark Rivers
Next: Re: delay before alarm on alarm handler James F Ross
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: delay before alarm on alarm handler James F Ross
ANJ, 20 Apr 2015 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
