1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: drvAsynIPPort question
To: [email protected]
Date: Wed, 20 Mar 2013 13:53:51 -0500
I would also agree that existing interfaces could be enhanced to simplify/clarify usage, without modifying what is already there. For example, in asynOctetSyncIO.h I see the following methods:
/*asynOctetSyncIO methods*/
static asynStatus connect(const char *port, int addr,
                               asynUser **ppasynUser, const char *drvInfo);
static asynStatus disconnect(asynUser *pasynUser);
static asynStatus openSocket(const char *server, int port,
                                         char **portName);
In particular, there is no "closeSocket()" method that I would expect to see (and that would match the "openSocket()" method). Similar statement can be made for various "configureIPXXX" methods.
Another possibility would be to introduce completely new package derived from existing asyn, that would not have to be backwards compatible.
Sinisa
On 03/20/2013 01:39 PM, J. Lewis Muir wrote:
On 3/20/13 12:43 PM, Mark Rivers wrote:
Unfortunately we need to live with these names, it's too late to change them now.
Hi, Mark.
Thanks for your explanation.  That is really confusing.
I agree that it's too late to change the names, but have you considered
adding new names?  That way, things could be more clear for new
development that doesn't need to be backward compatible.  It could also
make the documentation clearer since, for old names that are poor, you
could refer to the new names they map to.
To make new names, you could append the digit '2' to the names:
connect2, disconnect2, connectDevice2, etc.  Or you could add the words
'to' or 'from' to the names: connectTo, disconnectFrom, connectToDevice,
etc.  Or you could change the vocabulary to words like "bind", "attach",
etc.  Or there are probably other good schemes.
Lewis
Sinisa Veseli
Software Services Group
APS Engineering Support Division
Argonne National Laboratory
[email protected]
(630)252-9182
RE: drvAsynIPPort question Mark Rivers
drvAsynIPPort question Sinisa Veseli
Re: drvAsynIPPort question J. Lewis Muir
Prev: Re: drvAsynIPPort question J. Lewis Muir
Next: RE: drvAsynIPPort question Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
ANJ, 20 Apr 2015 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
