1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: epics-perl & perlapi-5.10.1
To: Martin Konrad <[email protected]>
Date: Mon, 11 Mar 2013 11:16:09 -0400
Hi Martin,
On 03/10/2013 07:43 AM, Martin Konrad wrote:
Hi Michael,
thank you for providing new Debian packages for EPICS 3.14.12.
Unfortunately I can only use them on squeeze but not on Ubuntu quantal
because quantal does not provide perlapi-5.10.1 but only perlapi-5.14.2.
Is it really necessary to depend on a fixed version of Perl or can you
also use something like "perl-base >= 5.10.1"?
The added dependency is caused by a change I made to where libCap5.so is installed for the 3.14.12 series. Previously if was installed in /usr/lib/epics/lib, now it is under /usr/share/perl5 (I'll check, but I think it should actually be in /usr/lib/perl5).
The dependency is emit by the dh_perl helper script when it finds that a package contains .so or .pm files in perl specific paths. So previously this wasn't being triggered because libCap5.so wasn't installed in the standard place.
As far as I can see this wasn't causing any issues as the only perl scripts using this module are caget.pl and friends (included in the epics-dev package).
So avoiding the perlapi-* dep for epics-dev means moving (or removing) these scripts. My current plan is to move CA.pm, libCap5.so, and the scripts which use them to a separate binary package. Thoughts?
Also, I hope to start providing builds for Debian Wheezy (7.0) this week. I'm still working on some issue with my pbuilder scripts.
Michael
Re: epics-perl & perlapi-5.10.1 Andrew Johnson
epics-perl & perlapi-5.10.1 Martin Konrad
Prev: Re: gethostbyname and getaddrinfo - multiple DNS entries for a hostname Michael Davidsaver
Next: Re: gethostbyname and getaddrinfo - multiple DNS entries for a hostname Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: epics-perl & perlapi-5.10.1 Martin Konrad
Next: Re: epics-perl & perlapi-5.10.1 Andrew Johnson
ANJ, 20 Apr 2015 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
