Hi all! Sorry for ask serveal simple questions.
Here is what I'm doing:
I had write a regular Ioc application connect with a board using TCP/IP socket. In the IOC, I use the system record type like ao, ai, bi and etc. So I have many records or PVs. And for each record I should send or receive different message to the board.
Now I want to write a new record type(nodeRecord) by myself instead of using system record type. Maybe it is not a good method.
But I want to have a try.
In the new record type(nodeRecord), I turn the previously IOC records to the nodeRecord's fields.
And I can access the fields in the client using ca library.
But I can't know what field was processed in the device support so that I can't konw what message I should send to the board.
So how do I konw which field I was processed in the device support?
Now I just compare the each field value and judge which field value was changed. This is too stupid.
Do you have any better ideals?
Thank you all!
- RE: write record device support Mark Rivers
Trio Motion support for Motor Record Miroslav Pavleski
I/O Intr scanning Vishnu Patel
<2013>
<2013>
