1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: RE: IOC device support
To: "[email protected]" <[email protected]>, tech-talk <[email protected]>
Date: Sat, 9 Mar 2013 04:14:04 +0000
In general you don't need to know what changed.
If the record calls a device support function, then the device support function should just access the current fields in the record and do what it is requested to do (write a new value, read a new value, etc.)
You have been posting a number of questions which are quite specific, and indicate that you are just learning EPICS.
- Writing a new record type
- Writing device support
I think it may be more useful to write a message that says what you are actually trying to do, and get advice from the community on the best way to do that.
- What type of device are you trying to communicate with
- What do you want to do with the device
It may turn out that the best way to do this is not to write a new record, or even to write new device support.
You should try to "start simple", and only write device support or record support if a simpler solution does not work.
From: [email protected] [[email protected]] on behalf of [email protected] [[email protected]]
Sent: Friday, March 08, 2013 7:19 PM
To: tech-talk
Subject: IOC device support
Hi all,
I have a trouble about IOC device support.
I have built a IOC application, and I should access to its PV in the client.
So Here is the question:
if I caput one of the PV's field, how could I know which field was processed in the device support? Just look at every field's value to check whether it is changed?
Does anybody know any better method?
thank you!
IOC device support ahwwq
Prev: Re: EDM Text Control Widget Motif behavior Bruce Hill
Next: Re: RE: IOC device support ahwwq
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: IOC device support ahwwq
ANJ, 20 Apr 2015 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
