1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: RE: Record support for binary serial communications?
To: <[email protected]>
Date: Fri, 8 Mar 2013 10:23:43 +0000
Stream device can handle binary I/O streams including null bytes using the %r or %R format converters.
-----Original Message-----
From: [email protected] [mailto:[email protected]] On Behalf Of Westfall, Michael D
Sent: 07 March 2013 17:40
To: [email protected]
Subject: Record support for binary serial communications?
Does anybody have any tips as how to communicate via a serial interface to a device that takes commands and gives responses in binary bytes rather than ASCII?  We are using EPICS R3.13.4, and it appears that streamDevice is not available, or would require some extensive hacking to get it to work. devAscii is available, but since it relies heavily on string scanning functions, it will likely choke on any data that contain null bytes.
Mike Westfall
Los Alamos
Scanned by iCritical.
Record support for binary serial communications? Westfall, Michael D
Prev: Re: Automatic IOC configuration loading Martin Konrad
Next: RE: Labview as Server and Probe as client, connection problem. kathryn.baker
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Re: Record support for binary serial communications? Andrew Johnson
Next: CSS at SLAC, anyone? Emmanuel Mayssat
ANJ, 20 Apr 2015 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
