1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: RTEMS-beatnik(MVME6100) network initialize error?
To: <[email protected]>
Cc: [email protected], [email protected]
Date: Thu, 7 Mar 2013 15:56:45 +0900
Hi all.
I tried to run EPICS ioc in RTEMS-beatnik(MVME6100), I got the following error message
***** Initializing network *****
Startup.
Link detected; attaching mve1
***** Initializing NFS *****
Mount 192.168.100.4:/var/lib/tftpboot on /home
RTEMS-RPCIOD $Release$, Till Straumann, Stanford/SLAC/SSRL 2002, See LICENSE file for licensing info.
RTEMS-NFS $Release$, Till Straumann, Stanford/SLAC/SSRL 2002, See LICENSE file for licensing info.
RPCIO: server '192.168.100.4' not responding - still trying
Unable to contact NFS server - invalid port? (RPC: Timed out)
mount failed: Unknown protocol
development environment
Epics base: 3.14.12.3
Rtems: 4.10.2
Os : centos 6.3 final
NFS Mount test to NFS server from Remote host was successful. But, mvme6100 was not.
First of all, ping test failed from remote host to mvme6100.
Please help me.
As an another problem, mvme6100 have two Ethernet port,
I want know how to set up in the rtems_netconfig.c
Below the mvme6100 gevShow, boot process, the epics netstat log.
Thanks you for your help.
Regards.
Mr. Mun.
MVME6100> gevShow
mot-script-boot
tftpGet -c192.168.100.180 -s192.168.100.4 -m255.255.255.0 -d/dev/enet0 -ftest.boot
netShut
go
mot-/dev/enet0-cipa=192.168.100.180
mot-/dev/enet0-sipa=192.168.100.4
mot-/dev/enet0-snma=255.255.255.0
epics-ntpserver=192.168.100.4
epics-nfsmount=192.168.100.4:/var/lib/tftpboot:/home
rtems-client-name=testIoc
rtems-dns-server=192.168.100.4
mot-/dev/enet0-file=test.boot
Total Number of GE Variables =9, Bytes Utilized =385, Bytes Free =3207
Copyright(C)2008-2009,Emerson Network Power-Embedded Computing,Inc.
All Rights Reserved
Copyright Motorola Inc. 1999-2007, All Rights Reserved
MOTLoad RTOS Version 2.0,  PAL Version 2.3 RM01
Fri Jan 23 14:47:54 MST 2009
MPU-Type             =MPC74x7
MPU-Int Clock Speed  =1266MHz
MPU-Ext Clock Speed  =133MHz
MPU-Int Cache(L2) Enabled, 512KB, L2CR =C0000000
MPU-Ext Cache(L3) Enabled, 2MB, 211MHz, L3CR =DC026000
PCI bus instance 0   =64 bit, 133 Mhz, PCI-X
PCI bus instance 1   =64 bit, PCI
Reset/Boot Vector    =Flash1
Local Memory Found   =40000000 (&1073741824)
User Download Buffer =006B7000:008B6FFF
MVME6100> tftpGet -c192.168.100.180 -s192.168.100.4 -m255.255.255.0 -d/dev/enet0 -ftest.boot
Network Loading from: /dev/enet0
Loading File: test.boot
Load Address: 006B7000
Download Buffer Size = 00200000
Client IP Address      = 192.168.100.180
Server IP Address      = 192.168.100.4
Gateway IP Address     = 192.168.100.253
Subnet IP Address Mask = 255.255.255.0
Network File Load in Progress...
Bytes Received =&1710608, Bytes Loaded =&1710608
Bytes/Second   =&855304, Elapsed Time =2 Second(s)
MVME6100>-----------------------------------------
config addr is 0xF1000CF8
config data is 0xF1000CFC
Welcome to RTEMS rtems-4.10.2(PowerPC/Generic (classic FPU)/beatnik)
CPU: MPC7457
Board Type: MVME6100-0173 (S/N E0F85A0)
Bus Clock Freq:   133333333 Hz
CPU Clock Freq:  1266666654 Hz
Memory:          1073741824 bytes
Now BSP_mem_size = 0x3FC00000
Configuration.work_space_size = A4D10
Page table setup finished; will activate it NOW...
Going to start PCI buses scanning and initialization
Number of PCI buses found is : 3
MSR 2003032
Exit from bspstart
unable to find the universe in pci config space
Tundra Tsi148 PCI-VME bridge detected at 0x81100000, IRQ 84
Tsi148 Outbound Ports:
Port  VME-Addr   Size       PCI-Adrs   Mode:
0:    0x20000000 0x0E000000 0x90000000 A32, SUP, D32, SCT
1:    0x00000000 0x00FF0000 0x9F000000 A24, SUP, D32, SCT
2:    0x00000000 0x00010000 0x9FFF0000 A16, SUP, D32, SCT
7:    0x00000000 0x01000000 0x9E000000 CSR, SUP, D32, SCT
Tsi148 Inbound Ports:
0:    0x90000000 0x3FC00000 0x00000000 A32, PGM, DAT, SUP, USR, MBLT, BLT
vmeTsi148 IRQ manager: looking for registers on VME...
Trying to find CSR on VME...
vmeTsi148 - IRQ manager using VME CSR to flush FIFO
Registering /dev/console as minor 0 (==/dev/ttyS0)
Startup.
rtems_bsdnet_get_ntp() Can't send: Host is down
***** Starting EPICS application *****
testIoc>
testIoc> netstat
************ INTERFACE STATISTICS ************
***** mve1 *****
Ethernet Address: EC:9E:CD:09:72:85
Address:192.168.100.180 Broadcast Address:192.168.100.255 Net mask:255.255.255.0
Flags: Up Broadcast Running Simplex Multicast
Send queue limit:50   length:0    Dropped:0
mve1 Statistics:
  # IRQS:                 7
  Max. mbuf chain length: 1
  # repacketed:           0
  # packets:              7
MIB Counters:
  GOOD_OCTS_RCVD:      0
  BAD_OCTS_RCVD:       229348
  INTERNAL_MAC_TX_ERR: 0
  GOOD_FRAMES_RCVD:    0
  BAD_FRAMES_RCVD:     14
  BCAST_FRAMES_RCVD:   0
  MCAST_FRAMES_RCVD:   0
  FRAMES_64_OCTS:      7
  FRAMES_65_127_OCTS:  0
 FRAMES_128_255_OCTS: 0
  FRAMES_256_511_OCTS: 0
  FRAMES_512_1023_OCTS:0
  FRAMES_1024_MAX_OCTS:0
  GOOD_OCTS_SENT:      448
  GOOD_FRAMES_SENT:    7
  EXCESSIVE_COLL:      0
  MCAST_FRAMES_SENT:   0
  BCAST_FRAMES_SENT:   7
  UNREC_MAC_CTRL_RCVD: 0
  FC_SENT:             0
  GOOD_FC_RCVD:        0
  BAD_FC_RCVD:         0
  UNDERSIZE_RCVD:      0
  FRAGMENTS_RCVD:      14
  OVERSIZE_RCVD:       0
  JABBER_RCVD:         0
  MAC_RX_ERR:          0
  BAD_CRC_EVENT:       0
  COLL:                0
  LATE_COLL:           0
***** lo0 *****
Address:127.0.0.1       Net mask:255.0.0.0
Flags: Up Loopback Running Multicast
************ MBUF STATISTICS ************
mbufs:16384    clusters:2560    free:2520
drops:   0       waits:   0  drains:   0
      free:16342         data:42          header:0           socket:0
       pcb:0           rtable:0           htable:0           atable:0
    soname:0           soopts:0           ftable:0           rights:0
    ifaddr:0          control:0          oobdata:0
testIoc>
Re: RTEMS-beatnik(MVME6100) network initialize error? Till Straumann
Re: RTEMS-beatnik(MVME6100) network initialize error? Feng Laurence
Prev: Re: initHookFunction and asynPortDriver Zenon Szalata
Next: RE: device support tom.cobb
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Next: Re: RTEMS-beatnik(MVME6100) network initialize error? Till Straumann
ANJ, 20 Apr 2015 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
