1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: CSS Boy - creating OPI files with parameters
Date: Thu, 7 Mar 2013 10:19:09 +0000
I would like to create a panel to be used with IO device with many channels. I am now wondering if there is a way how to set PV to widgets like parameters (e.g. to set PVs to $device:DIO:$port_$channel and then set those parameters/variables in some startup scrip or Java code common for the whole panel? Or is there other recommanded way how to do that?
I am also wandering if there is a way how to trigger a script associated with the widget by an action not related to the PV (e.g. I would like to change color of a widget if a button is pressed)?
I have just started with BOY so my question is probably stupid, but I was not able to find a solution in a documentation I have read so far….
Thanks in advance for help!
Cheers,
Mike
Re: CSS Boy - creating OPI files with parameters Ralph Lange
RE: CSS Boy - creating OPI files with parameters Chen, Xihui
Prev: RE: device support tom.cobb
Next: Re: CSS Boy - creating OPI files with parameters Ralph Lange
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Re: RTEMS-beatnik(MVME6100) network initialize error? Till Straumann
ANJ, 20 Apr 2015 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
