Hi Mark,
I am wondering if there is functionality in asynPortDriver or asyn as
such for having a callback routine be called at various stages of the DB
initialization. I would like to use something like the EPICS
initHookFunction. The problem with it is that it is a static function
with no mechanism that I see to pass to it a pointer to my device driver
class object, so that from the callback routine the correct instance of
the device driver can be called. I have a situation where I have a few
identical VME ADC boards and for each of these boards I create an object
of the class (derived from asynPortDriver).
I have klugged this as a function which I invoke from st.cmd file after
IOC initialization is done. This works fine unless I need to have a bit
more control when the routine is called, like after some phase of the DB
init other than after all initialization is done.
Sorry for bugging you about this,
Zen
- Re: initHookFunction and asynPortDriver Eric Norum
device support Sinclair, John William
<2013>
<2013>
ANJ, 20 Apr 2015 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
EPICS V4
IRMIS
Talk
Bugs
Documents
Links
Licensing
