1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: What I learned today...
To: <[email protected]>
Date: Fri, 1 Mar 2013 15:55:42 +0100
On Thursday, February 28, 2013 11:22:06 Andrew Johnson wrote:
> On 2013-02-28 Michael Davidsaver wrote:
> > On 02/28/2013 09:57 AM, Benjamin Franksen wrote:
> > > (1) The script can be called more often than necessary:
> > I don't think this is the case as long as the command
> > './create_some_files.pl' creates all three files (which I assume it what
> > you intended).
> If the target files can be created from more than one architecture and are
> generated in the O.Common directory or get installed into one of the common
> top-level directories (db, dbd, etc.) then you get this kind of problem, and
> it's actually very hard if not impossible to prevent a race between
> different target builds because they are not synchronized.
> We get around that in Base now by always generating files into the O.<arch>
> directory and moving them into O.Common afterwards.  A move is an atomic
> operation in the file-system, so it doesn't matter if there is a race
> because the generated files *should* be identical.
But won't this mean that architecture independent targets (db files,dbd
files,operator panels, etc.) will all be built several timesd (once for each
target architecture)?
I may be missing something, but it seems to me that if
CROSS_COMPILER_TARGET_ARCHS contains more entries than the machine has cores,
make -j with rules that are as you describe above will be slower than serial
make with the old make rules, at leats if the build time is dominated by such
architecture independent targets. The latter is the case if e.g. device lists
and configuration data are generated by scripts that query a SQL database
server.
Cheers
Ben Franksen
()  ascii ribbon campaign - against html e-mail
/\  www.asciiribbon.org   - against proprietary attachments
Attachment: signature.asc
Description: This is a digitally signed message part.
Re: What I learned today... Andrew Johnson
What I learned today... Benjamin Franksen
Re: What I learned today... Michael Davidsaver
Prev: Re: seq: benign(?) error message when building with R3.15 Benjamin Franksen
Next: Re: What I learned today... Michael Davidsaver
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Re: What I learned today... Andrew Johnson
Next: Re: What I learned today... Andrew Johnson
ANJ, 20 Apr 2015 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
