1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: seq: benign(?) error message when building with R3.15
To: Benjamin Franksen <[email protected]>
Cc: [email protected]
Date: Thu, 28 Feb 2013 18:11:44 -0600
Hi Benjamin,
On 2013-02-28 Benjamin Franksen wrote:
> with the latest snapshot (http://www-
> csr.bessy.de/control/SoftDist/sequencer/releases/seq-snapshot-latest.tar.gz
>  or darcs get
>  http://www-csr.bessy.de/control/SoftDist/sequencer/repo/branch-2-1/ ) I
>  can build the sequencer reliably under 3.15.0.1 (all patches applied),
>  even with parallel make. however, I get a spurious message saying
>   Can't find file 'vxTestHarnessRegistrars.dbd'
> that I do not understand and do not get with base 3.14.12.2. It looks as if
> the build is ok despite the message (make runtests runs through just fine),
> but if you have a hint how to get rid of the message I'd be glad.
I get several different issues.  Using the latest 3.15 branch code and a
serial build the first error I saw was this:
/usr/bin/g++ -o decl  -L/home/phoebus3/ANJ/epics/modules/soft/seq-
snapshot-2013-02-28/lib/linux-x86_64 -
L/home/phoebus3/ANJ/epics/base/mirror-3.15/lib/linux-x86_64 -Wl,-
rpath,/home/phoebus3/ANJ/epics/modules/soft/seq-snapshot-2013-02-28/lib/linux-
x86_64 -Wl,-rpath,/home/phoebus3/ANJ/epics/base/mirror-3.15/lib/linux-x86_64
-m64 decl.o -lseqSoftIoc -lseq -lpv -ldbRecStd -ldbCore -lca -lCom
decl.o: In function `main':
snapshot-2013-02-28/test/validate/O.linux-x86_64/../seqMain.c:118: undefined
reference to `seqSoftIoc_registerRecordDeviceDriver'
collect2: ld returned 1 exit status
make[3]: *** [decl] Error 1
make[3]: Leaving directory `/home/phoebus3/ANJ/epics/modules/soft/seq-
snapshot-2013-02-28/test/validate/O.linux-x86_64'
I immediately went to the test/validate directory and ran make there.
    tux% make
    make: `vxTestHarness.db' is up to date.
Huh?  In the O.linux-x86_64 directory I get the same seqMain error from above.
This is happening because in your test/validate/Makefile the rule for
vxTestHarness.db$(DEP) appears *above* the "include $(TOP)/configure/RULES"
line, contrary to the comment that follows.  All rules *must* go below that
include or they interfere with the default rule.  You should probably check
the other Makefiles for that too, I haven't looked.
With that issue out of the way, the seqMain error is happening because my 3.15
build has gcc's -fvisibility=hidden flag set.  That makes it essential to
properly decorate all symbols that are going to be exported from a shared
library, thus matching the behavior of DLLs built on Windows.  Unfortunately
the generated seqSoftIoc_registerRecordDeviceDriver() function is not (and
can't be) decorated, so it's not actually possible to link it from a library.
You have to link the .o file directly into each of your executables instead.
I removed the seqSoftIoc library from your Makefile and added the magic to set
    xxx_SRCS = xxx.st $(seqSoftIoc_SRCS)
for all your test programs.
Ok, Finally I can see your error:
    tux% make -sj4
    tux%
Where is it coming from?  Well if I run a serial make and look at the output
it occurs here:
perl -CSD /home/phoebus/ANJ/epics/base/mirror-3.15/bin/linux-
x86_64/makeIncludeDbd.pl base.dbd ../O.Common/vxTestHarnessRegistrars.dbd
vxTestHarnessInclude.dbd
make[1]: Leaving directory `/home/phoebus3/ANJ/epics/modules/soft/seq-
make[1]: Entering directory `/home/phoebus3/ANJ/epics/modules/soft/seq-
The fact that this came from the first build pass (when GNUmake says "Leaving"
followed by "Entering" the same directory) usually indicates that it's a
problem generating a dependency file, and in this case you don't have a rule
to generate the vxTestHarness.dbd$(DEP) file.  If I add that as well the error
goes away:
    tux% make clean
    rm -rf O.linux-x86_64 O.vxWorks-ppc604_long O.vxWorks-ppc32
     O.vxWorks-ppc32sf O.RTEMS-uC5282 O.Common
    tux% make -sj4
    tux%
I also ran the tests on linux-x86_64, which all passed BTW.
You don't need to set USR_DBDFLAGS for 3.15 so I commented it out, but I guess
it may be necessary for some earlier release of Base.
Patch file attached, but I only tried this with the latest 3.15 branch.
- Andrew
There is no such thing as a free lunch.  When invited for lunch,
it is best to check if you are there to eat, or to be eaten.
-- Clive Robinson
--- Makefile.orig	2013-02-28 15:30:52.362346140 -0600
+++ Makefile	2013-02-28 18:02:16.091655151 -0600
@@ -62,20 +62,14 @@
 #TESTPROD_HOST += ctest
 #  Libraries
-PROD_LIBS += seqSoftIoc
 PROD_LIBS += seq pv
 PROD_LIBS += $(EPICS_BASE_IOC_LIBS)
-LIBRARY += seqSoftIoc
 DBD += seqSoftIoc.dbd
 seqSoftIoc_DBD += base.dbd
 seqSoftIoc_SRCS += seqSoftIoc_registerRecordDeviceDriver.cpp
-seqSoftIoc_LIBS += seq pv
-seqSoftIoc_LIBS += $(EPICS_BASE_IOC_LIBS)
 ifeq '$(EPICS_HAS_UNIT_TEST)' '1'
 seqSoftIoc_SRCS += testSupport.c
@@ -91,15 +85,17 @@
 vxTestHarness_DBD += base.dbd
 vxTestHarness_DBD += $(COMMON_DIR)/vxTestHarnessRegistrars.dbd
-USR_DBDFLAGS += -I $(COMMON_DIR)
-TOUCH = $(PERL) -MExtUtils::Command -e touch
+# USR_DBDFLAGS += -I $(COMMON_DIR)
 DB += vxTestHarness.db
-vxTestHarness.db$(DEP):
-	$(TOUCH) $@
 endif
+define template_SRCS
+$(1)_SRCS += $(1).st $(seqSoftIoc_SRCS)
+endef
+$(foreach st, $(TESTPROD_HOST), $(eval $(call template_SRCS,$(st))))
 # PROD_RTEMS = rtemsTestHarness
 # rtemsTestHarness_SRCS += $(TESTPROD_HOST::%=%.st)
@@ -109,6 +105,13 @@
 #  ADD RULES AFTER THIS LINE
+ifeq '$(EPICS_HAS_UNIT_TEST)' '1'
+vxTestHarness.db$(DEP):
+	@echo "$(COMMON_DIR)/vxTestHarness.db: ../Makefile" > $@
+vxTestHarness.dbd$(DEP):
+	@echo "$(COMMON_DIR)/vxTestHarness.dbd: ../Makefile" > $@
+endif
 SOFTIOC=$(EPICS_BASE_BIN)/softIoc$(HOSTEXE)
 SOFTDBD=$(EPICS_BASE)/dbd/softIoc.dbd
Re: seq: benign(?) error message when building with R3.15 Benjamin Franksen
Prev: RE: Crystal Logic goniometer Mark Rivers
Next: 答复: Crystal Logic goniometer 汪启胜
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: seq: benign(?) error message when building with R3.15 Benjamin Franksen
Next: Re: seq: benign(?) error message when building with R3.15 Benjamin Franksen
ANJ, 20 Apr 2015 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
