1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: Problem building EPICS 3.14.12.3 on Cygwin
Date: Thu, 28 Feb 2013 13:41:43 -0600
On 2/27/13 6:43 PM, Mark Rivers wrote:
> I don't know how to make that process better, but copying and reconciling the CONFIG_SITE files between EPICS releases is one of the most tedious and error prone parts of upgrading EPICS base.
Hi, Mark.
I agree that this is a pain.  What I do is keep track of exactly what
changes I make to configure files (all files, actually).  This list of
changes can be as simple as a diff.  For an upgrade, I check each change
and see if it's necessary in the new version.
Another possible approach might be something like OpenBSD's sysmerge
tool [1].  It helps perform the task of updating configuration files
after an upgrade by walking through differences and offering a chance to
merge.  EPICS Base could provide something similar, maybe called
"epicscfgmerge", to work on EPICS configuration files.
Lewis
1. Search for "sysmerge" at <http://www.openbsd.org/cgi-bin/man.cgi>
Problem building EPICS 3.14.12.3 on Cygwin Mark Rivers
Re: Problem building EPICS 3.14.12.3 on Cygwin Andrew Johnson
RE: Problem building EPICS 3.14.12.3 on Cygwin Mark Rivers
Prev: Re: Strange Interaction between CA gateway and CAJ Eric Norum
Next: areaDetector R1-9 released Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: RE: Problem building EPICS 3.14.12.3 on Cygwin Mark Rivers
Next: Get /usr/lib/libXm.a error while building MEDM Yasemin Barutçu
ANJ, 20 Apr 2015 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
