1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: RE: Get /usr/lib/libXm.a error while building MEDM
To: Yasemin Barutçu <[email protected]>, "[email protected]" <[email protected]>
Date: Thu, 28 Feb 2013 13:52:38 +0000
When I searched "libXm.a" file, it seemed to be in /usr/lib folder.
yasemin@yasemin-Veriton-M490G:/opt/epics/extensions/src/medm$ sudo apt-file search libXm.a
lesstif2-dev: /usr/lib/libXm.a
libmotif-dev: /usr/lib/i386-linux-gnu/libXm.a
libmotif-dev: /usr/lib/libXm.a
Is that actually searching for the file on your system, or is it showing you what packages (lesstif2-dev, libmotif-dev contain a file called libXm.a?  What do you get if you do:
ls -l /usr/lib/libXm.a
From: [email protected] [[email protected]] on behalf of Yasemin Barutçu [[email protected]]
Sent: Thursday, February 28, 2013 3:07 AM
To: [email protected]
Subject: Get /usr/lib/libXm.a error while building MEDM
I've been trying to build MEDM. Files are ;
1. baseR3.14.12.3
2.extensionsConfig_20040406
3.extensionsTop_20120904
4.medm3_1_7
I am getting following problem.
Error
make[2]: Entering directory `/opt/epics/extensions/src/medm/medm/O.linux-x86'
make[2]: *** No rule to make target `/usr/lib/libXm.a', needed by `medm'. Stop.
make[2]: Leaving directory `/opt/epics/extensions/src/medm/medm/O.linux-x86'
make[1]: *** [install.linux-x86] Error 2
make[1]: Leaving directory `/opt/epics/extensions/src/medm/medm'
make: *** [medm.install] Error 2
I configure the "CONFIG_SITE.linux-x86.linux-x86" file.
X11_LIB=/usr/lib
X11_INC=/usr/X11
MOTIF_LIB=/usr/lib
MOTIF_INC=/usr/include
I change X11_LIB as /usr/lib because in /usr/lib/X11, there are 5 folders;
1.bindings
2.rstart
3.x11perfcomp
4.xedit
5.xsm
Best Regards,
Yasemin Barutçu
Get /usr/lib/libXm.a error while building MEDM Yasemin Barutçu
Prev: Building an Epics module only for a target (not host) Florian Feldbauer
Next: RE: Installing MEDM on UBUNTU 12.04 Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Get /usr/lib/libXm.a error while building MEDM Yasemin Barutçu
Next: Installing MEDM on UBUNTU 12.04 Yasemin Barbar
ANJ, 20 Apr 2015 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
