1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: RE: EPICS Modbus module + PLC
To: EPICS Tech Talk <[email protected]>
Cc: Roze Jean-François <[email protected]>
Date: Fri, 22 Feb 2013 14:14:59 +0000
For the Spiral2 project in construction at Ganil, we will use Siemens PLCs linked to the control system using Modbus servers either from an Ethernet coupler board or directly from the PLC CPU.
Eric Lécorché
De : [email protected] [mailto:[email protected]] De la part de Dudley, David
Envoyé : vendredi 22 février 2013 14:36
À : EPICS Tech Talk
Objet : Re: EPICS Modbus module + PLC
A couple of the facilities here are using EPICS Modbus with Siemens S7-200 CPUS.  We've also used it on Apentec and Mirion Radiation monitor systems.
Later-
David
On Feb 22, 2013, at 8:06 AM, Daniel Piso <[email protected]> wrote:
Hi all,
We are using Modbus EPICS support on Twido PLC and it is working fine.  If you ask us we can provide further details.
Best Regards,
Daniel Piso
El 22/02/2013 13:16, Pavel Maslov escribió:
Good day all,
Has anyone tried Modbus EPICS support on PLCs other than Koyo?
Best regards,
Pavel Maslov, MS
Controls Engineer at Pulsed power Lab
Efremov Institute for Electro-Physical Apparatus
St. Petersburg, Russia
Mobile: +7 (951) 672 22 19
Landline: +7 (812) 461 01 01
Re: EPICS Modbus module + PLC Paul Nord
EPICS Modbus module + PLC Pavel Maslov
Re: EPICS Modbus module + PLC Daniel Piso
Re: EPICS Modbus module + PLC Dudley, David
Prev: Re: EPICS Modbus module + PLC Rod Nussbaumer
Next: Problem when cross-compiling epics base for vxWorks5.5 on win32-x86 王林
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Re: EPICS Modbus module + PLC Dudley, David
Next: Re: EPICS Modbus module + PLC Paul Nord
ANJ, 20 Apr 2015 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
