1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: asyn and snmp
To: Eric Norum <[email protected]>, Paul Nord <[email protected]>
Date: Thu, 21 Feb 2013 15:10:45 -0500
I dont think it's an issue with the environment variable.  I tried
commenting them out and it gave the same syntax error about the
dbLoadDatabase command.
The IOC isn't getting far enough to get to the console output.  Here
is what I do after building it:
1. cd <TOP>/iocBoot/iocsnmp
2. ./st.cmd
Output:
./st.cmd: line 7: syntax error near unexpected token `"MIBDIRS",'
./st.cmd: line 7: `epicsEnvSet("MIBDIRS", "+$(TOP)/mibs")'
I'm running scientific linux 5.8 with epics base 3.14.12.1.
Thanks
James
On Thu, Feb 21, 2013 at 2:56 PM, Eric Norum <[email protected]> wrote:
> That's strange.  Can you send all the IOC console output?
> What IOC platform are you using?
> I tried downloading, unpacking and building the SNMP tarball.  When I run it I get:
> #!../../bin/darwin-x86/wienerCrateExample
> # Set up environment
> # Need to add run-time expansion for crate support
> epicsEnvSet("P","wienerCrate:")
> epicsEnvSet("R","1:")
> < envPaths
> epicsEnvSet("ARCH","darwin-x86")
> epicsEnvSet("IOC","iocwienerCrateExample")
> epicsEnvSet("TOP","/Users/wenorum/src/SNMP/snmp/WienerCrate")
> epicsEnvSet("SNMP","/Users/wenorum/src/SNMP/snmp")
> epicsEnvSet("EPICS_BASE","/usr/local/epics/R3.14.12/base")
> epicsEnvSet("MIBDIRS", "+/Users/wenorum/src/SNMP/snmp/WienerCrate/mibs")
> epicsEnvSet("WCR_PREF", "admin WIENER-CRATE-MIB::")
> # Register all support components
> On Feb 21, 2013, at 11:42 AM, James F Ross <[email protected]> wrote:
>> Paul,
>> Ok, I'm starting from scratch with John's basic IOC and I'm going to
>> write a very basic IOC just to turn the crate on and off and maybe
>> read the voltages and currents.
>> At the moment i'm trying to get the basic IOC to run, though, and am
>> running into the following problem.  I've emailed john but if you have
>> any insight, that'd be nice as well:
>> ./st.cmd
>> The mib file is in that directory, so I'm not sure what it is
>> complaining about.  This is written into his st.cmd file, I didn't
>> change anything.
>> James
> Eric Norum
> [email protected]
Re: asyn and snmp Paul Nord
Re: asyn and snmp Eric Norum
asyn and snmp James F Ross
Re: asyn and snmp James F Ross
Prev: Re: asyn and snmp Eric Norum
Next: Re: asyn and snmp Paul Nord
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
ANJ, 20 Apr 2015 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
