1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: asyn and snmp
To: James F Ross <[email protected]>
Date: Thu, 21 Feb 2013 11:56:34 -0800
That's strange.  Can you send all the IOC console output?
What IOC platform are you using?
I tried downloading, unpacking and building the SNMP tarball.  When I run it I get:
#!../../bin/darwin-x86/wienerCrateExample
# Set up environment
# Need to add run-time expansion for crate support
epicsEnvSet("P","wienerCrate:")
epicsEnvSet("R","1:")
< envPaths
epicsEnvSet("ARCH","darwin-x86")
epicsEnvSet("IOC","iocwienerCrateExample")
epicsEnvSet("TOP","/Users/wenorum/src/SNMP/snmp/WienerCrate")
epicsEnvSet("SNMP","/Users/wenorum/src/SNMP/snmp")
epicsEnvSet("EPICS_BASE","/usr/local/epics/R3.14.12/base")
epicsEnvSet("MIBDIRS", "+/Users/wenorum/src/SNMP/snmp/WienerCrate/mibs")
epicsEnvSet("WCR_PREF", "admin WIENER-CRATE-MIB::")
# Register all support components
On Feb 21, 2013, at 11:42 AM, James F Ross <[email protected]> wrote:
> Paul,
> Ok, I'm starting from scratch with John's basic IOC and I'm going to
> write a very basic IOC just to turn the crate on and off and maybe
> read the voltages and currents.
> At the moment i'm trying to get the basic IOC to run, though, and am
> running into the following problem.  I've emailed john but if you have
> any insight, that'd be nice as well:
> ./st.cmd
> ./st.cmd: line 7: syntax error near unexpected token `"MIBDIRS",'
> ./st.cmd: line 7: `epicsEnvSet("MIBDIRS", "+$(TOP)/mibs")'
> The mib file is in that directory, so I'm not sure what it is
> complaining about.  This is written into his st.cmd file, I didn't
> change anything.
> James
Eric Norum
[email protected]
Re: asyn and snmp James F Ross
Re: asyn and snmp Paul Nord
Prev: Re: asyn and snmp James F Ross
Next: Re: asyn and snmp James F Ross
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
ANJ, 20 Apr 2015 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
