1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: asyn and snmp
To: EPICS Tech Talk <[email protected]>
Date: Thu, 21 Feb 2013 11:41:45 -0500
Hello everyone,
As I mentioned in a previous email I'm trying to write an IOC that
controls a wiener PL508 crate via snmp.  I have one that controls a
PL512 crate and I'm trying to understand it so I can write an IOC for
the PL508.
At the moment, I'm focusing on how the .db files get the information
from snmp.  The following record is a good example:
record(ai, "HFT:PXL:U$(Ch):GetDemandVoltage")
    field(DTYP,"asynFloat64")
    field(INP,"@asyn($(IP) $(Ch) .1) Demand_Voltage")
    field(SCAN,"5 second")
    field(LINR,"LINEAR")
Where Ch can be 0 through 11 and IP is the IP address of the crate.
I believe that the key is this field:
This should correspond to one of the following variables (obtained via
snmpwalk).  I think the first is most likely the variable that the
field gets its input from.
WIENER-CRATE-MIB::outputVoltage.u0 = Opaque: Float: 4.500000 V
WIENER-CRATE-MIB::outputMeasurementSenseVoltage.u0 = Opaque: Float: 0.000000 V
WIENER-CRATE-MIB::outputMeasurementTerminalVoltage.u0 = Opaque: Float:
0.000000 V
Does anyone know where a good guide to using asyn with snmp would be?
Or perhaps a general epics/snmp guide?  I just need to know how
"@asyn($(IP) $(Ch) .1) Demand_Voltage" points to outputVoltage.u0 and
what I should put in other INP fields for other crate variables.
Thanks!
James
Re: asyn and snmp Eric Norum
Re: asyn and snmp Paul Nord
Prev: Re: Rounding in conversion of ao record haquin
Next: Re: asyn and snmp Eric Norum
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
ANJ, 20 Apr 2015 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
