1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: aSub MAX_ARRAY_SIZE increase
To: [email protected]
Cc: [email protected]
Date: Mon, 18 Feb 2013 12:38:16 -0600
Hi Euan,
On 2013-02-17 [email protected] wrote:
> I have an EPICS application that runs on Linux/Darwin where I need to
> increase the value of MAX_ARRAY_SIZE in aSubRecord.c from ten million to
> 200 million or possibly even 1000 million. Apart from creating a version
> of EPICS that is only locally compatible (and needing lots of memory to
> run) are there any likely problems with this change?
We have removed the MAX_ARRAY_SIZE limitation from the aSub record in the 3.15
branch of Base, although I don't think that's in any released version yet.
Your modified version should work fine.
- Andrew
There is no such thing as a free lunch.  When invited for lunch,
it is best to check if you are there to eat, or to be eaten.
-- Clive Robinson
aSub MAX_ARRAY_SIZE increase Euan.Troup
Prev: RE: aSub MAX_ARRAY_SIZE increase Dalesio, Leo
Next: gateway: strange configuration Pierrick Hanlet
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Next: Spring 2013 EPICS Collaboration Meeting: Registration Open ian.gillingham
ANJ, 20 Apr 2015 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
