1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: record info field in which epics version?
To: Emmanuel Mayssat <[email protected]>
Cc: [email protected]
Date: Fri, 15 Feb 2013 17:16:08 -0600 (CST)
dbgrep
To: "Andrew Johnson" <[email protected]>, [email protected]
Sent: Friday, February 15, 2013 4:42:46 PM
Subject: RE: record info field in which epics version?
I would like to be able to filter PVs from a running IOC based on a tag (best candidate may be info record field)
Is there a way to do an operation equivalent to
dbl * where $record.info.my_tag= "foo" > file.pv ?
PS: almost like a SQL query!
E
> From: [email protected]
> To: [email protected]
> Date: Fri, 15 Feb 2013 10:10:22 -0600
> Hi,
> On 2013-02-15 Ralph Lange wrote:
> > On 02/15/2013 02:42 AM, Emmanuel Mayssat wrote:
> > > In which epics version did the 'info field' for record appears?
> > > I can't find any reference to it in the Release notes.
> > 3.14.3 (released September 2003)
> Possibly even earlier, the commit that added them is dated August 2000. They
> never existed on the 3.13 branch however.
> - Andrew
> There is no such thing as a free lunch. When invited for lunch,
> it is best to check if you are there to eat, or to be eaten.
> -- Clive Robinson
RE: record info field in which epics version? Emmanuel Mayssat
Prev: RE: record info field in which epics version? Emmanuel Mayssat
Next: Re: record info field in which epics version? Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
ANJ, 20 Apr 2015 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
