g+
g+ Communities
Argonne National Laboratory
1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013 Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013
Subject: header files in snc code
To: Tech Talk <tech-talk@aps.anl.gov>
Date: Fri, 8 Feb 2013 12:04:27 -0600
I'm building a state machine in which I will have ~100 variables which I will monitor
and to which I will write.  I would like to make my source code more clear by putting
this list in a header file.  I could not find anything in the documentation other than
including a c-style header file with the appropriate "%%".  Can I add a header file
in which I make all of the assignments and monitors?
Thank you,
Pierrick
"Whether you think you can or think you can't, either way, you are correct" -- Henry Ford
_______________________________________________________________
Pierrick Hanlet
IIT/Fermilab
+1-630-840-5555 (FNAL)
+1-312-567-5745 (IIT)
+1-630-697-8758/+44-79-48-860-197 (US/UK mobile)
Re: header files in snc code Tim Mooney
Prev: Re: Problem with mca R7.2 and Rontec XFlash Zachary Brown
Next: Re: header files in snc code Tim Mooney
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013
Prev: support module for Xspress 3 matthew.pearson
ANJ, 08 Feb 2013 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
· EPICSv4 · IRMIS · Talk · Bugs · Documents · Links · Licensing ·
