g+
g+ Communities
Argonne National Laboratory
1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013 Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013
Subject: Re: Problem with mca R7.2 and Rontec XFlash
To: jlmuir@imca-cat.org
Cc: tech-talk@aps.anl.gov
Date: Fri, 8 Feb 2013 11:25:20 -0500
We are using RS232.  Using the XFlash unit as configured through spec does not show the same delay as the IOC.  Disabling the Temperature monitoring PV (:ReadTemperature) which is on a 1s scan-rate, seems to alleviate the problem a bit.
-ZB
On 2/6/13 11:00 AM, Phillip Sorensen wrote:
> Hello,
> We are tring to setup the Rontec XFlash MCA with epics using the R7.2
> version of mca.
> The problem we are having is there seems to be a delay of some number of
> seconds after sending a command until we see an update in the MEDM
> screen.  For example clicking the start and stop buttons for the
> acquisition show this.  I we look at the XFlash unit it seems to update
> the front panel immediately, but the MEDM screen shows a delay.  The
> spectrum update (which is set to 1 second) also seems to take 5 to 10
> seconds per update.
> We are not getting any timeout errors.  Any suggestions?
Hi, Phil.
Over what physical link are you communicating with the XFlash?  If it's
RS-232, it could just take that long to transmit the data over the slow
link.
Lewis
RE: Problem with mca R7.2 and Rontec XFlash Mark Rivers
Prev: support module for Xspress 3 matthew.pearson
Next: header files in snc code Pierrick Hanlet
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013
Prev: Re: Problem with mca R7.2 and Rontec XFlash J. Lewis Muir
Next: RE: Problem with mca R7.2 and Rontec XFlash Mark Rivers
ANJ, 11 Feb 2013 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
· EPICSv4 · IRMIS · Talk · Bugs · Documents · Links · Licensing ·
