g+
g+ Communities
Argonne National Laboratory
1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013 Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013
Subject: Cannot connect to MASAR server
To: "tech-talk@aps.anl.gov" <tech-talk@aps.anl.gov>, "shengb@bnl.gov" <shengb@bnl.gov>
Date: Tue, 5 Feb 2013 10:31:07 -0800
Following the docs at
I installed masar.
The installation is relatively smooth.
But when I try to start the server and then the client, I get
"Cannot connect to MASSAR server. Please .... "
Client and server are running on the same machine.
epics2@cr1dev1 $ ./bin/linux-x86_64/masarServiceRun MASARSERVICE:TEST:EXAMPLE
VERSION : pvAccess Server v1.2-SNAPSHOT
PROVIDER_NAMES : pvService
BEACON_ADDR_LIST :
AUTO_BEACON_ADDR_LIST : 1
BEACON_PERIOD : 15
BROADCAST_PORT : 5076
SERVER_PORT : 5075
RCV_BUFFER_SIZE : 16384
IGNORE_ADDR_LIST:
STATE : INITIALIZED
===Starting channel RPC server: MASARSERVICE:TEST:EXAMPLE
===Use CTRl-D or exit() command to stop MASARSERVICE:TEST:EXAMPLE server.
masarService>
The server seems to be running correctly.
In another terminal, I start the pyqt client
epics2@cr1dev1 $ python masar MASARSERVICE:TEST:EXAMPLE
Which returns the 'cannot connect' error message...
I tried connecting with the API
Python 2.7.3 (default, Jul 24 2012, 11:41:40)
[GCC 4.6.3 20120306 (Red Hat 4.6.3-2)] on linux2
Type "help", "copyright", "credits" or "license" for more information.
>>> import sys
>>> from masarclient import masarClient
>>> from masarclient.channelRPC import epicsExit
>>> channel='MASARSERVICE:TEST:EXAMPLE'
>>> mc = masarClient.client(channelname = channel)
>>> result = mc.retrieveSystemList()
Traceback (most recent call last):
  File "<stdin>", line 1, in <module>
  File "/home/local/epics/middleware/4.20130201/masarService/python/masarclient/masarClient.py", line 70, in retrieveSystemList
    nttable = self.__clientRPC(function, params)
  File "/home/local/epics/middleware/4.20130201/masarService/python/masarclient/masarClient.py", line 42, in __clientRPC
    if not channelRPC.waitConnect(1.0) :
  File "/home/local/epics/middleware/4.20130201/masarService/python/masarclient/channelRPC.py", line 75, in waitConnect
    result = channelRPCPy._waitConnect(self.cppPvt,timeout);
SystemError: error return without exception set
It seems that the server and clients cannot see each others.
Am I missing something?
Emmanuel
Re: Cannot connect to MASAR server Shen, Guobao
Prev: RE: (epics-python) Cothread egg installation Emmanuel Mayssat
Next: Re: Cannot connect to MASAR server Shen, Guobao
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013
ANJ, 05 Feb 2013 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
· EPICSv4 · IRMIS · Talk · Bugs · Documents · Links · Licensing ·
