As Guobao has pointed out, if you try to import cothread from within its source directory then you might get unexpected results. However, you can fix this
problem by running this command (you don’t need sudo for this):
python setup.py build_ext –i
This will ensure that _coroutine.so is built in the source directory, which is useful if you want to work with the sources. However, as you’ve already run
‘python setup.py install’, also try changing to another directory and see if ‘import cothread’ works there.
I presume that you didn’t mean to write ‘cothread.utils’ below? I don’t recognise it, you probably mean ‘cothread.catools’.
From: Emmanuel Mayssat [mailto:emayssat@outlook.com]
Sent: 05 February 2013 02:07
To: tech-talk@aps.anl.gov; Abbott, Michael (DLSLtd,RAL,DIA)
Subject: (epics-python) Cothread egg installation
Michael,
I am in the middle of the installation of the epics4 masarService (python based Save Compare Restore)
Cothread is a dependency.
After downloading 2-8, I ran
sudo python setup install
Everything seems to run smoothly
Thereafter to test the installation, I do
Python 2.7.3 (default, Jul 24 2012, 11:41:40)
[GCC 4.6.3 20120306 (Red Hat 4.6.3-2)] on linux2
Type "help", "copyright", "credits" or "license" for more information.
>>> from cothread.utils import *
Traceback (most recent call last):
File "<stdin>", line 1, in <module>
File "cothread/__init__.py", line 41, in <module>
File "cothread/cothread.py", line 79, in <module>
ImportError: cannot import name _coroutine
This e-mail and any attachments may contain confidential, copyright and or privileged material, and are for the use of the intended addressee only. If you are not the intended addressee or an authorised recipient of the addressee please notify us of receipt by returning the e-mail and do not use, copy, retain, distribute or disclose the information in or attached to the e-mail. Any opinions expressed within this e-mail are those of the individual and not necessarily of Diamond Light Source Ltd. Diamond Light Source Ltd. cannot guarantee that this e-mail or any attachments are free from viruses and we cannot accept liability for any damage which you may sustain as a result of software viruses which may be transmitted in or with the message. Diamond Light Source Limited (company no. 4375679). Registered in England and Wales with its registered office at Diamond House, Harwell Science and Innovation Campus, Didcot, Oxfordshire, OX11 0DE, United Kingdom
