This might be caused by the page file being too small, and or because of a memory leak in the software. I don’t know
of a leak, but we have to always consider the possibility. The memory leak situation can sometimes be identified when it is related to a linear increase in the virtual size of the Linux process correlated somehow to time or client initiated activity. The gateway
does use free lists so its virtual size will remain at the high water mark of memory usage initiated by client load.
Jeff
wantianmin [mailto:wantianmin@gmail.com]
Sent: Friday, February 01, 2013 6:08 AM
To: Hill, Jeff
Subject: epics gateway error message
yestoday , When I check the epics gateway status,
I found these error messages ,I am not sure about what happens.
I notice your messge (forward message to the email address)
So I paste these message and send to you.
by the way:
my epics gateway running on these environment:
OS: Linux (Centos,5.4,kernel:2.6.18-164.15.1.e15.centos.plusPAE)
EPICS: base-3.14-11
gateway: 2_0_4_0
gcc,g++ version: gcc-4.1.2
I hope these information is helpful to you.
Error messages:
Jan 31 19:12:16 !!! Errlog message received (message is above)
timerQueue: Unexpected C++ exception "St9bad_alloc" with type "St9bad_alloc" during timer expiration callback
at Thu Jan 31 2013 19:12:26.313131210
Jan 31 19:12:26 !!! Errlog message received (message is above)
the _expression_ "this->numSubscriptions == 0" didnt evaluate to boolean true
and therefore internal problems are suspected at line 65 in "../../../../src/cas/generic/casEventSys.cc"
Please forward above text to johill@lanl.gov - thanks
numSubscriptions=1
filename="../../../../src/cas/generic/st/casStreamOS.cc" line number=479
Memory allocation failed - unexpected problem with client's input - forcing disconnect
Jan 31 20:37:04 !!! Errlog message received (message is above)
at Thu Jan 31 2013 20:37:14.081768211
Jan 31 20:37:14 !!! Errlog message received (message is above)
numSubscriptions=1
Jan 31 20:37:24 !!! Errlog message received (message is above)
Jan 31 20:37:34 !!! Errlog message received (message is above)
Jan 31 20:37:46 !!! Errlog message received (message is above)
filename="../../../../src/cas/generic/st/casStreamOS.cc" line number=605
Re: Analog data acquisition in an EMI environment Pavel Maslov
<2013>
Job Openings at APS Nicholas Schwarz
(epics-python) Cothread egg installation Emmanuel Mayssat
<2013>
ANJ, 04 Feb 2013 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
EPICSv4
IRMIS
Talk
Bugs
Documents
Links
Licensing
