g+
g+ Communities
Argonne National Laboratory
1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013 Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013
Subject: Java, CAJ, DNS RE: CSS addr_list bug
To: Paul Sichta <psichta@pppl.gov>, "tech-talk@aps.anl.gov" <tech-talk@aps.anl.gov>
Date: Thu, 31 Jan 2013 11:55:28 -0500
Hi:
The error is not specific to CSS or BOY.
Your example is in CAJ, the pure Java Channel Access library.
There can be related issues with Java network code in general.
I've seen similar errors when the Java network code could not get the DNS name for the local host.
In all these cases, checking the log can help.
Kay
From: tech-talk-bounces@aps.anl.gov [tech-talk-bounces@aps.anl.gov] On Behalf Of Paul Sichta [psichta@pppl.gov]
Sent: Wednesday, January 30, 2013 12:51 PM
To: tech-talk@aps.anl.gov
Subject: CSS addr_list bug
Bug:
A colleague discovered strange behavior today, where only some of our
IOC's were connecting with a BOY display.  In CSS
Preferences->CSS_Core->EPICS, in the addr_list field,  I enter the
names of my IOC's. I de-select the auto_addr_list.
If I mistype or put a name there which isn't resolved in our DNS,
every IOC after that in the list will not connect (after restarting
CSS).  I get the error below in the CSS Console.  If the IOC is simply
down, then all others in the list connect normally, as expected.
2013-01-30 12:26:39.664 SEVERE [Thread 11]
com.cosylab.epics.caj.impl.BroadcastTransport (send) -
java.io.IOException: Target address not resolved
Work-around:
type carefully
-ps
CSS addr_list bug Paul Sichta
Prev: Re: Analog data acquisition in an EMI environment Paul Sichta
Next: Re: Analog data acquisition in an EMI environment Pavel Maslov
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013
Prev: CSS addr_list bug Paul Sichta
Next: Job Openings at APS Nicholas Schwarz
ANJ, 01 Feb 2013 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
· EPICSv4 · IRMIS · Talk · Bugs · Documents · Links · Licensing ·
