g+
g+ Communities
Argonne National Laboratory
1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013 Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013
Subject: Re: Save/Compare/Restore Application
To: Emmanuel Mayssat <emayssat@outlook.com>
Cc: "tech-talk@aps.anl.gov" <tech-talk@aps.anl.gov>
Date: Wed, 30 Jan 2013 13:28:45 -0500
Hi Emmanuel,
MASAR is developed with all tech you mentioned: Python, PyQt, SQLite.
The server side uses SQLite as back-end data storage engine. All configurations and data are stored in SQLite.
The access to SQLite is thru a python interface, which I called it pymasar. With pymasar, although it is not the
desired way, but if you wish, you are able to play with the MASAR RDB directly.
The client side provides Python interface for scripting users. A GUI is also available, which is based on the client
Python interface and developed with PyQt.
The comparing is inside the Client side.
The restore function is added in the PyQt part, which needs cothread module.
Here is a list of modules dependency:
 - EPICS V3 (most likely, libCom)
 - EPICS V4 (pvData, pvAccess, pvIOC, and normativetype)
 - SQLite
 - Python 2.7.x
 - PyQt
According the requirement you mentioned in your previous, I believe we can do it in the client interface.
I am very interesting to work on that.
Guobao
On 1/30/13 1:00 PM, Emmanuel Mayssat wrote:
Guabao,
I found the mercurial repository (although for some reason I cannot access it, but that maybe on my side)
Is EPICS V4 required?
I have an EPICS V3.14.11 installation....
E
To: shengb@bnl.gov; emmanuel_mayssat@lynceantech.com
Subject: RE: Save/Compare/Restore Application
Date: Wed, 30 Jan 2013 09:51:49 -0800
CC: tech-talk@aps.anl.gov
Guabao,
SCORE is Java based and here we are using .... python (as well as Qt, pyqt, SQLlite, and Fedora 16)!
So our preference go to MASAR, but....
I looked at the documentation and noticed some interesting features.
Assuming I have a signal with white noise that is captured in a ai record,
if I compare its current and previously saved value, there are likely to be different.
Is there a way to say that for that PV, if the value is within 3 standard dev (configurable per PV) then do not report the PV as different?
Are the sources MASAR available?
Is this software packaged and ready to be distributed?
If so, where is a download page?
Emmanuel
To: emayssat@outlook.com
Date: Wed, 30 Jan 2013 03:27:00 +0000
Hi Emmanuel,
Here at NSLS II, we have developed a tool for this purpose, which I named it MASAR, and are using it for our beam commissioning.
It is capable to take a snapshot with any pv combination, for example with scalar pv and waveform pv.
An online user manual can be found at
There are sections to explain how to compile everything from source, and run a demo.
I have all binary packages against Debian 7. If you want them, I can send to you.
Guobao
On Jan 29, 2013, at 8:00 PM, "Emmanuel Mayssat" <emayssat@outlook.com> wrote:
Hello,
I am exploring save/compare/restore applications out there as I intend to replace ours.
To date, I am only aware of SCORE used at ORNL.
Is anyone on this mailing list maintaining/developing/administrating SCORE?
Is anybody using something else? If so, what? Is there a project web page?
Emmanuel
RE: Save/Compare/Restore Application Emmanuel Mayssat
Re: Save/Compare/Restore Application Shen, Guobao
Prev: Job Openings at APS Nicholas Schwarz
Next: Re: Analog data acquisition in an EMI environment Pavel Maslov
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013
Prev: RE: Save/Compare/Restore Application Emmanuel Mayssat
Next: RE: Save/Compare/Restore Application Emmanuel Mayssat
ANJ, 05 Feb 2013 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
· EPICSv4 · IRMIS · Talk · Bugs · Documents · Links · Licensing ·
