Hi James, Are you running devIocStats? http://www.slac.stanford.edu/grp/cd/soft/epics/site/devIocStats/ If so, memory is available as a PV whose value you could record in any number of ways. Tim
From: "James F Ross" <james.falconer.ross@gmail.com> To: "EPICS Tech Talk" <Tech-talk@aps.anl.gov> Sent: Monday, January 28, 2013 10:18:52 AM Subject: memory and vxWorks based IOCs
Hello everyone, I suppose this is more a vxWorks question than an epics question, but here is the issue. I've got a VME based IOC running here at STAR that is having memory problems. Basically we noticed this issue as every 24-48 hours the IOC would lose communication and all GUIs associated with it would go blank. The solution is to re-start the IOC by rebooting the VME, but doing this every day is not a good solution.
The epics is running on vxWorks, so I can use the memShow command to show the memory usage at a given time. I can see that as I open more and more GUIs, the memory fills up. At least part of the cause of the loss of communication has to do with too many people opening GUIs relating to this IOC at the same time. However, I am not certain that this is the only problem.
What I would like is to track the memory usage over time to see if there is a time component as well as just too many GUIs being opened. Does anyone know how to do this in vxWorks? Get it to print its memory usage every minute or so to a log file or something similar?
Thanks James
- Re: memory and vxWorks based IOCs James F Ross
- memory and vxWorks based IOCs James F Ross
RE: BOY number representation & display scaling Chen, Xihui
Re: unable to tunnel CA through ssh tunnel Till Straumann
<2013>
<2013>
ANJ, 28 Jan 2013 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
EPICSv4
IRMIS
Talk
Bugs
Documents
Links
Licensing
