g+
g+ Communities
Argonne National Laboratory
1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013 Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013
Subject: RE: Can't read MIME Types file
To: Pierrick Hanlet <hanlet@fnal.gov>, Tech Talk <tech-talk@aps.anl.gov>
Date: Mon, 28 Jan 2013 06:22:16 -0500
Hi:
Did you try the “ArchiveDataServerStandalone” as described in section 4.3.5 of http://ics-web.sns.ornl.gov/kasemir/archiver/manual.pdf with the DemoData directory?
That directory contains an example setup which includes abyss.conf and  an abyss/ subdir with mime.types etc.
Once that works, follow the manual directions:
"..copy all “abys*” files and directories from there <meaning: DemoData directory> into the directory where you intend to run the standalone data serve"
That way, you should have the abyss/mine.types file in the right place.
Kay
_______________________________________
From: tech-talk-bounces@aps.anl.gov [tech-talk-bounces@aps.anl.gov] On Behalf Of Pierrick Hanlet [hanlet@fnal.gov]
Sent: Sunday, January 27, 2013 5:46 PM
To: Tech Talk
Subject: Can't read MIME Types file
Hi all,
I have a linux box running 2.6.18-274 with epics 3.14.11.
I'm attempting to use the Channel Archiver stand alone abyss web server.  Using
the ThirdParty software, I successfully built everything that I need (I think). Yet
when I attempt to start the stand alone data server, I get the error message:
"Can't read MIME Types file 'abyss/mime.types'
This is simply an ascii file.  It exists and has similar permissions to other builds that
I have.  Any ideas on this?
BTW, this is a separate thread than my 32bit to 64bit question.  I urgently need this
information, so I'm trying on another machine for the moment.
Pierrick
"Whether you think you can or think you can't, either way, you are correct" -- Henry Ford
_______________________________________________________________
Pierrick Hanlet
IIT/Fermilab
+1-630-840-5555 (FNAL)
+1-312-567-5745 (IIT)
+1-630-697-8758/+44-79-48-860-197 (US/UK mobile)
Can't read MIME Types file Pierrick Hanlet
Prev: Can't read MIME Types file Pierrick Hanlet
Next: unable to tunnel CA through ssh tunnel Andre Charbonneau
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013
ANJ, 28 Jan 2013 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
· EPICSv4 · IRMIS · Talk · Bugs · Documents · Links · Licensing ·
