g+
g+ Communities
Argonne National Laboratory
1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013 Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013
Subject: Re: BOY number representation & display scaling
To: tech-talk@aps.anl.gov
Date: Fri, 25 Jan 2013 22:01:13 -0500
To suppress the comma for 1,000's:
In java.text.NumberFormat;
I need to specify  setgroupingused(false) for that value.  So, this I
cannot change in the Basic_EPICS package I downloaded from SNS.
-ps
On Fri, Jan 25, 2013 at 6:00 PM, Paul Sichta <psichta@pppl.gov> wrote:
> Exploring BOY-land from medm.
> 1) Using BOY, I want large numbers to be displayed with no comma.
> e.g.  145,123 I want to display as 145123
> Widget type text update, format type decimal. Tried format string and
> that showed gibberish. Also tried a few others widget types to no
> avail. I tried several LC_NUMERIC environment settings before css
> launch, no help there.
> Any ideas?
> 2) With medm, when I resized a display's window the entire display
> scaled.  With BOY this is not the behavior - you just shrink the
> visible portion of the display.  To shrink/enlarge/scale the entire
> display takes several steps and the F8 key.  Is there a trick or
> setting to rescale the entire display - widgets, text, objects?  Does
> a WebOPI display behave any differently in this regard?
> just some comments on my experience:
> Had success with SNS Basic_EPICS version.
> I was very impressed with how quickly I was able to adl2boy our 400
> medm displays.  Most needed a tweak (compound visibility rule) and
> some wouldn't convert (shell script launcher?)  but basically they all
> worked. adl2boy worked on my 32-bit RHEL5 Basic_EPICS but not on my
> 64-bit RHEL_5.
> I like the tabbing feature when additional displays are brought up,
> but I also like to arrange many displays across numerous operator
> screens - often shrinking the displays to get more on there all
> visible at once.  I added an action button to each display to 'detach'
> ;  that gets me my displays on independent windows.  I tried to drag
> the display's tab out of the window but this didn't work.  I also
> thought a right-click option to 'detach' would also be useful ...I
> know  I know, if I want that feature then code it up  :).  But my
> window resize/rescale issue remains.  The operators are used to this
> feature.
> -ps
BOY number representation & display scaling Paul Sichta
Prev: Re: copying archived data from 32-bit to 64-bit machine James F Ross
Next: Re: copying archived data from 32-bit to 64-bit machine Pierrick Hanlet
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013
Prev: RE: BOY number representation & display scaling Kasemir, Kay
Next: RE: BOY number representation & display scaling Chen, Xihui
ANJ, 28 Jan 2013 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
· EPICSv4 · IRMIS · Talk · Bugs · Documents · Links · Licensing ·
