Hi Mark,
On 01/22/2013 03:48 PM, Mark Rivers wrote:
Hi Hinko,
I was expecting that $(P)ElapsedRealTime would hold some other time
value - maybe cumulative for all MCA channels..
That PV holds the maximum elapsed real time for any channel. The calculation is done at line 2821 in NDDxp.cpp:
getDoubleParam(i, mcaElapsedRealTime, &realTime);
realTime = MAX(realTime, dvalue);
Line 2821 in NDDxp.cpp is more or less EOF in the code I'm looking at -
dxpR3-1. But on line 1814 and 1815 I can find the lines you are
referring too. Thanks!
Correct me if I'm wrong, the DXP system can be composed of different
number of channels (1 - 16 or even more). So the $(P)ElapsedRealTime
shows the maximum Real time as seen by any of the active channels
belonging to the DXP system.
Also since the 16element_dxp.adl looks like a "top" level panel, for
controling 16 detector channels, why would we need to make a separate
instance of it (according to dxpDoc.html) for each detector channel?
It is a top-level panel and you don't need to make a separate instance of it for each detector channel. I searched dxpDoc.html for the string 16element_dxp.adl and I don't see any mention of making separate instances of it. Can you please send me the text that you are referring to?
I was reading this on some printed sheets I have - but I do not have
them at hand. The statement is more a deduction from compiling several
information from the code, DB and docs I have, rather than a direct
statement in the docs.
The implication was that dxpHighLevel.template defines the
$(P)ElapsedRealTime the 16element_dxp.adl is showing it. Since
16element_dxp.adl is obviously top level panel, I was surprised to see
it was showing a PV from the template that is instantiated multiple
times (dxpHighLevel.template). That is why the statement "according to
dxpDoc.html" was made, because it indeed does say, in the
dxpHighLevel.template section:
".. One instance of this database is loaded for each detector channel in
the system. .."
Looking at the online versions of panels, templates and docs again, I
can't find the use of $(P)ElapsedRealTime in any ADL panel - only
$(P)ElapsedReal is used. I need to verify this info with my printed docs
later on this week.
Hinko
-----Original Message-----
From: tech-talk-bounces@aps.anl.gov [mailto:tech-talk-bounces@aps.anl.gov] On Behalf Of Hinko Kocevar
Sent: Tuesday, January 22, 2013 7:20 AM
To: Tech Talk
Subject: DXP ElapsedRealTime
I'm trying to understand how the counting of Elapsed Real Time is done
in the $(P)ElapsedRealTime record found in dxpHighLevel.template and
seen on 16element_dxp.adl panel.
I can understand that each MCA record (seen in the mca_simple.adl)
counts its own Elapsed real time in the .ERTM field.
Best regards,
Hinko Kocevar
- RE: DXP ElapsedRealTime Mark Rivers
- DXP ElapsedRealTime Hinko Kocevar
Re: Edm installation Mauro Giacchini
<2013>
<2013>
