g+
g+ Communities
Argonne National Laboratory
1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013 Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013
Subject: RE: DXP ElapsedRealTime
To: "'Hinko Kocevar'" <hinko.kocevar@i-tech.si>, Tech Talk <tech-talk@aps.anl.gov>
Date: Tue, 22 Jan 2013 14:48:08 +0000
Hi Hinko,
> I was expecting that $(P)ElapsedRealTime would hold some other time
> value - maybe cumulative for all MCA channels..
That PV holds the maximum elapsed real time for any channel.  The calculation is done at line 2821 in NDDxp.cpp:
           getDoubleParam(i, mcaElapsedRealTime, &realTime);
           realTime = MAX(realTime, dvalue);
> Also since the 16element_dxp.adl looks like a "top" level panel, for
> controling 16 detector channels, why would we need to make a separate
> instance of it (according to dxpDoc.html) for each detector channel?
It is a top-level panel and you don't need to make a separate instance of it for each detector channel.  I searched dxpDoc.html for the string 16element_dxp.adl and I don't see any mention of making separate instances of it.  Can you please send me the text that you are referring to?
-----Original Message-----
From: tech-talk-bounces@aps.anl.gov [mailto:tech-talk-bounces@aps.anl.gov] On Behalf Of Hinko Kocevar
Sent: Tuesday, January 22, 2013 7:20 AM
To: Tech Talk
Subject: DXP ElapsedRealTime
I'm trying to understand how the counting of Elapsed Real Time is done
in the $(P)ElapsedRealTime record found in dxpHighLevel.template and
seen on 16element_dxp.adl panel.
I can understand that each MCA record (seen in the mca_simple.adl)
counts its own Elapsed real time in the .ERTM field.
Best regards,
Hinko Kocevar
Re: DXP ElapsedRealTime Hinko Kocevar
Prev: DXP ElapsedRealTime Hinko Kocevar
Next: sequencer programs in an IOC James F Ross
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013
Next: Re: DXP ElapsedRealTime Hinko Kocevar
ANJ, 23 Jan 2013 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
· EPICSv4 · IRMIS · Talk · Bugs · Documents · Links · Licensing ·
