g+
g+ Communities
Argonne National Laboratory
1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013 Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013
Subject: Re: femto and std
To: Tim Mooney <mooney@aps.anl.gov>
Cc: Tech Talk <tech-talk@aps.anl.gov>
Date: Mon, 21 Jan 2013 09:53:47 -0600
Hi Tim,
Thanks for your help.  I've gotten much further, but was unable to complete the build of the
test facility withing seq.  However, I was successful in building std without it.  I was traveling
yesterday when I received your response, so I'm only now getting back to this.
Now, I'm back to my ioc.  As previously written, I've successfully built all of this code on
another machine. When I do a line-by-line comparison of the execution of the Makefile
on the successful build vs new build, I find that my new build fails at the point that the
successful build prints "converting ../sncMICEStates.stt" (immediately after expanding
the dbd file).  My new build gives the line:
make[3]: *** No rule to make target sncMICEStates.o', needed by libMICEStatesSupport.a'.  Stop
Pierrick
On 01/20/2013 10:45 AM, Tim Mooney wrote:
Hi Pierrick,
First, make sure that std/configure/RELEASE has a line like the following:
    SNCSEQ=$(SUPPORT)/seq
or
    SNCSEQ=home/controls/support/seq
Then, replace seq/configure/RULES_BUILD with the following:
    ifdef SNCSEQ
     SNC = $(SNCSEQ)/bin/$(EPICS_HOST_ARCH)/snc$(HOSTEXE)
    else
     ifdef SEQ
      SNC = $(SEQ)/bin/$(EPICS_HOST_ARCH)/snc$(HOSTEXE)
     else
      SNC = $(INSTALL_LOCATION)/bin/$(EPICS_HOST_ARCH)/snc$(HOSTEXE)
     endif
    endif
Then, do a "make rebuild" in seq and std.
Tim
----- Original Message -----
To: "Tech Talk" <tech-talk@aps.anl.gov>
Sent: Sunday, January 20, 2013 9:37:16 AM
Subject: femto and std
I followed the thread on techtalk but did not find a solution to the
problem regarding building std.
I don't have a 64 bit machine. I'm using 3.14.11 and std-3.1 or
std-2.8
and seq-2.1.11. This does
build on a couple of other machines I'm using.
/usr/bin/gcc -c  -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS
-D_XOPEN_SOURCE=500           -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux
-D_REENTRANT   -O3   -Wall      -m32     -g -fPIC -I. -I../O.Common
-I.
-I.. -I../../../include/os/Linux -I../../../include
-I/home/controls/support/seq/include
-I/home/controls/support/asyn4-19/include
-I/home/epics/base-3-14-11/include/os/Linux
-I/home/epics/base-3-14-11/include        ../pvHistory.c
make[3]: *** No rule to make target `femto.o', needed by `libstd.a'.
 Stop.
Pierrick
"Whether you think you can or think you can't, either way, you are
correct" -- Henry Ford
_______________________________________________________________
*Pierrick Hanlet*
IIT/Fermilab
+1-630-840-5555 (FNAL)
+1-312-567-5745 (IIT)
+1-630-697-8758/+44-79-48-860-197 (US/UK mobile)
"Whether you think you can or think you can't, either way, you are correct" -- Henry Ford
Pierrick Hanlet
IIT/Fermilab
Re: femto and std Tim Mooney
Prev: Re: femto and std Tim Mooney
Next: DXP ElapsedRealTime Hinko Kocevar
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013
ANJ, 22 Jan 2013 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
· EPICSv4 · IRMIS · Talk · Bugs · Documents · Links · Licensing ·
