g+
g+ Communities
Argonne National Laboratory
1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013 Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013
Subject: Re: femto and std
To: Pierrick Hanlet <hanlet@fnal.gov>
Cc: Tech Talk <tech-talk@aps.anl.gov>
Date: Sun, 20 Jan 2013 10:45:22 -0600 (CST)
Hi Pierrick,
First, make sure that std/configure/RELEASE has a line like the following:
    SNCSEQ=$(SUPPORT)/seq
or
    SNCSEQ=home/controls/support/seq
Then, replace seq/configure/RULES_BUILD with the following:
    ifdef SNCSEQ
     SNC = $(SNCSEQ)/bin/$(EPICS_HOST_ARCH)/snc$(HOSTEXE)
    else
     ifdef SEQ
      SNC = $(SEQ)/bin/$(EPICS_HOST_ARCH)/snc$(HOSTEXE)
     else
      SNC = $(INSTALL_LOCATION)/bin/$(EPICS_HOST_ARCH)/snc$(HOSTEXE)
     endif
    endif
Then, do a "make rebuild" in seq and std.
Tim
----- Original Message -----
> From: "Pierrick Hanlet" <hanlet@fnal.gov>
> To: "Tech Talk" <tech-talk@aps.anl.gov>
> Sent: Sunday, January 20, 2013 9:37:16 AM
> Subject: femto and std
> Hi,
> I followed the thread on techtalk but did not find a solution to the
> problem regarding building std.
> I don't have a 64 bit machine. I'm using 3.14.11 and std-3.1 or
> std-2.8
> and seq-2.1.11. This does
> build on a couple of other machines I'm using.
> /usr/bin/gcc -c  -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS
> -D_XOPEN_SOURCE=500           -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux
> -D_REENTRANT   -O3   -Wall      -m32     -g -fPIC -I. -I../O.Common
> -I.
> -I.. -I../../../include/os/Linux -I../../../include
> -I/home/controls/support/seq/include
> -I/home/controls/support/asyn4-19/include
> -I/home/epics/base-3-14-11/include/os/Linux
> -I/home/epics/base-3-14-11/include        ../pvHistory.c
> make[3]: *** No rule to make target `femto.o', needed by `libstd.a'.
>  Stop.
> Thanks,
> Pierrick
> "Whether you think you can or think you can't, either way, you are
> correct" -- Henry Ford
> _______________________________________________________________
> *Pierrick Hanlet*
> IIT/Fermilab
> +1-630-840-5555 (FNAL)
> +1-312-567-5745 (IIT)
> +1-630-697-8758/+44-79-48-860-197 (US/UK mobile)
Re: femto and std Pierrick Hanlet
Prev: femto and std Pierrick Hanlet
Next: Re: femto and std Pierrick Hanlet
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013
ANJ, 21 Jan 2013 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
· EPICSv4 · IRMIS · Talk · Bugs · Documents · Links · Licensing ·
