Hi Pavel, In BOY script, you can use the standard Python or Java code to read/write file. The problem is that you cannot directly work with workspace path. You need to call FileUtil.workspacePathToSysPath(String) to convert a workspace path to system file path. Cheers, Xihui From: Pavel Maslov [mailto:pavel.masloff@gmail.com] Sent: Tuesday, January 15, 2013 2:32 AM To: EPICS Tech Talk Subject: [CSS] FileUtil Is there an opportunity to implement the binary read/write file functionality to the class FileUtil in CSS BOY? I can only see the writeTextFile() and readTextFile() functions in this API. Or there may be another way to read/write a binary file in CSS BOY? -- Best regards,
Pavel Maslov, MS Controls Engineer at Pulsed power Lab Efremov Institute for Electro-Physical Apparatus St. Petersburg, Russia
Mobile: +7 (951) 672 22 19 Landline: +7 (812) 461 01 01 |
- [CSS] FileUtil Pavel Maslov
EPICS Spring Collaboration Meeting Pre-meeting events austen.rose
Re: problem about edm widget Jason Abernathy
<2013>
sequencer release 2.1.11 Benjamin Franksen
<2013>
ANJ, 16 Jan 2013 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
EPICSv4
IRMIS
Talk
Bugs
Documents
Links
Licensing
