Thanks Andrew, Keith,
I'll give it a go with the CONFIG_SITE.<arch>.<arch> approach.
I've made some DEB packages that our developer can use on their machines
- to simplify the development. But the thing is that different versions
of the same OS that we use have the same libraries stored in different
folders.
Best regards,
Hinko
On 01/10/2013 06:50 PM, keith.thorne@ligo.org wrote:
Dear Kate, Hinko
I agree with Andrew here. The solution is to edit the CONFIG_SITE
files. I have just been through getting EPICS building on 64-bit
Ubuntu12.
I had to make the following changes (see attached small patch files)
Change X11_LIB location in configure/os/CONFIG_SITE.linux-x86_64.linux-x8_64
(extensions_config_Ubuntu12.patch)
Correct probe1_1_7_0 Makefile to group X* libraries correctly by Motif/X11
(probe1_1_7_0-Ubuntu12.patch)
[ old versions of other extensions may need this as well ]
Correct Makefiles for SDDS, SDSSepics 2.11 to handle default SOA behavior
(got these from SDDS maintainer - may be added to newer releases)
(SDDS.2.11-Ubuntu12.patch, SDDSepics.2.11-Ubuntu12.patch)
All but the config patch should were for older Linux releases as well
Keith Thorne
LIGO CDS Software Engineer
Kate, Hinko,
On 2013-01-10 Hinko Kocevar wrote:
ln -snf /usr/lib/i386-linux-gnu/libXt.a /usr/lib/libXt.a
On 01/10/2013 04:18 AM, Kate Feng wrote:
ln -f -s /usr/lib/.../libxt.a libXt.a
It should /never/ be necessary to create soft-links like that, you just
have
to edit your extensions/configure/CONFIG_SITE file or if you're sharing a
build tree between multiple architectures the appropriate
extensions/configure/os/CONFIG_SITE.<arch>.<arch> files to tell the build
system where the relevant libraries can be found. Once you have correctly
set
the X11_LIB and/or MOTIF_LIB variables (and the _INC variables if
necessary)
for one product (say medm) it is then correct for any other products (say
StripTool) that you build in the same extensions tree.
This should be the more friendly solution that Hinko was asking for.
- Andrew
There is no such thing as a free lunch. When invited for lunch,
it is best to check if you are there to eat, or to be eaten.
-- Clive Robinson
Hinko Kocevar
Software development engineer
Instrumentation Technologies d.d.
Velika pot 22, SI-5250 Solkan - Slovenia
T:+386 5 3352600, F:+386 5 3352601
E-mail: hinko.kocevar@i-tech.si
http://www.i-tech.si
The information transmitted is intended solely for the
addressee and may contain confidential and/or privileged
information. Any review, retention, disclosure or other use
by persons other than the intended recipient is prohibited.
If you received this in error, please notify the sender and
delete all copies.
- medm build D Peter Siddons
- Re: medm build Kate Feng
- Re: medm build Hinko Kocevar
- Re: medm build Andrew Johnson
- Re: medm build keith . thorne
Re: routing Pavel Maslov
PCASpy 0.4 release Xiaoqiang Wang
<2013>
Re: medm build D Peter Siddons
Re: medm build Jeong Han Lee
<2013>
