g+
g+ Communities
Argonne National Laboratory
1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013 Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013
Subject: RE: dbScan.c: periodicTask( ), initOnce( ), ...
To: "'Andrew Johnson'" <anj@aps.anl.gov>, "tech-talk@aps.anl.gov" <tech-talk@aps.anl.gov>
Date: Thu, 10 Jan 2013 18:55:33 +0000
Hi Jack,
Additional to Andrew's comments on initOnce(), here is my two cents:
1. The function for the thread "scanOnce" (shown as you type "epicsThreadShowAll" in the Linux IOC shell) is actually onceTask(), not scanOnce(). The scanOnce() is a global function which is called by many other routines including scanShutdown() in dbScan.c, recGblFwdLink() in EPICS_BASE/src/db/recGbl.c, etc.;
2. Inside the infinite loop in onceTask(), it waits for the epicsEvent "onceSem" which is issued from scanOnce() (epicsEventSignal(onceSem)). Once it gets "onceSem", it will process all records in the Ring buffer if the IOC is not being shutdown;
3. The whole chain works like this: scanShutdown() or recGblFwdLink() or ... --> scanOnce() --> epicsEventMustWait(onceSem) in onceTask() --> ...
HTH,
Yong
-----Original Message-----
From: tech-talk-bounces@aps.anl.gov [mailto:tech-talk-bounces@aps.anl.gov] On Behalf Of Andrew Johnson
Sent: Thursday, January 10, 2013 12:05 PM
To: tech-talk@aps.anl.gov
Subject: Re: dbScan.c: periodicTask( ), initOnce( ), ...
Hi Jack,
Eric answered Q1, I'll tackle Q2:
On 2013-01-10 Jack Smith wrote:
> 2. Why do we need initOnce( ) in scanInit( )?
The IOC initialization code calls scanInit() at the appropriate time during iocInit(), the purpose of which is to initialize the dbScan subsystem, i.e.
create data the structures it needs and start its threads.  The three local routines initOnce(), initPeriodic() and initEvent() that scanInit() calls initialize the three different kinds of scan operation supported by the dbScan
subsystem: The initOnce() routine configures and starts the "scanOnce" thread,
initPeriodic() counts and configures (but doesn't actually start) the periodic scan threads, and initEvent() configures the "scanEvent" data structures.
HTH,
- Andrew
There is no such thing as a free lunch.  When invited for lunch, it is best to check if you are there to eat, or to be eaten.
-- Clive Robinson
dbScan.c: periodicTask( ), initOnce( ), ... Jack Smith
Re: dbScan.c: periodicTask( ), initOnce( ), ... Andrew Johnson
Prev: Re: routing Andrew Johnson
Next: Re: medm build D Peter Siddons
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013
Prev: Re: dbScan.c: periodicTask( ), initOnce( ), ... Andrew Johnson
Next: duplicating process variables James F Ross
ANJ, 10 Jan 2013 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
· EPICSv4 · IRMIS · Talk · Bugs · Documents · Links · Licensing ·
