Hi Pavel,
Firstly, we can’t see how the record "$(P)$(R)WF1 gets processed. Is there any forward link to this record? for instance,
record(… , "$(P)$(R)wf1")
field(FLNK,
"$(P)$(R)WF1")
If no, you may add CP or CPP in INPA, INPB, INCC, such as field(INCC, "$(P)$(R)wf1 CP").
Secondly, you may set "$(P)$(R)WF1.MDEL to -1, which means the monitor is triggered whenever the record is scanned. Then, camonitor “"$(P)$(R)WF1”.
But I’m not sure if this works for the acalcout record.
Lastly, I’m not quite sure if you used the "Store" operator correctly for "AA:=CC*5/128*A-B;AA". Does it mean: evaluate the _expression_ CC*5/128*A-B,
store the result in the input array AA, and set the AVAL field to AA?
Yong
tech-talk-bounces@aps.anl.gov [mailto:tech-talk-bounces@aps.anl.gov] On Behalf Of
Pavel Maslov
Sent: Thursday, January 10, 2013 2:05 AM
To: EPICS Tech Talk
Subject: acalcOut
Hello,
I am experiencing some difficulties with this record type.
record(acalcout, "$(P)$(R)WF1") {
field(INPA, "$(P)$(R)setY1:RBV")
field(INPB, "$(P)$(R)ch1pos:RBV")
field(INCC, "$(P)$(R)wf1")
field(CALC, "AA:=CC*5/128*A-B;AA")
I would like to plot an array in CSS 3.1.4. So I'm using an XY graph widget with the Y PV parameter pointed to $(P)$(R)WF1.AVAL.
However it does not put a monitor on the AVAL field. So the plot is not being updated every time the calculation is made.
Any suggestions will be much appreciated.
Best regards,
Pavel Maslov, MS
Controls Engineer at Pulsed power Lab
Efremov Institute for Electro-Physical Apparatus
St. Petersburg, Russia
Mobile: +7 (951) 672 22 19
Landline: +7 (812) 461 01 01
