g+
g+ Communities
Argonne National Laboratory
1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013 Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013
Subject: Re: dbScan.c: periodicTask( ), initOnce( ), ...
To: Jack Smith <jacksmithvent2009@gmail.com>
Cc: "tech-talk@aps.anl.gov" <Tech-talk@aps.anl.gov>
Date: Thu, 10 Jan 2013 06:51:50 -0800
On Jan 10, 2013, at 6:26 AM, Jack Smith <jacksmithvent2009@gmail.com> wrote:
> Hi Eric, Andrew, et al:
> Thanks for all your explanations. I tried Eric's codes and it works. I
> think Eric's algorithm is accurate enough for compensating the time
> spent on processing the records in its chain. Now, the delay in
> epicsEventWaitWithTimeout is (scan_period - time_on_scanList).
> Since I have more questions in dbScan.c, I am starting a new thread ...
> 1. In Eric's previous email, it says "It's the
> epicsEventWaitWithTimeout().  This allows the pause to be interrupted
> early in the case of IOC shutdown.". What does "This allows the pause
> to be interrupted early in the case of IOC shutdown" mean?
Think about what would happen if the periodTask loop just did an epicsThreadSleep at that point.  Things would work pretty much the same.  Well, they'd work the same until someone decided to shut down the IOC.  The SCAN="10 second" thread could take up to 10 seconds to reawaken and notice that ppsl->scanCtl == ctlExit and break out of the loop.
To avoid this problem the periodTask loop invokes epicsEventWaitWithTimeout to perform the delay.  When the IOC begins to shut down it sets  ppsl->scanCtl = ctlExit and raises the ppsl->loopEvent.  The epicsEventWaitWithTimeout then returns right away, the thread breaks out of the loop and terminates.
dbScan.c: periodicTask( ), initOnce( ), ... Jack Smith
Prev: dbScan.c: periodicTask( ), initOnce( ), ... Jack Smith
Next: RE: acalcOut Hu, Yong
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013
Next: Re: dbScan.c: periodicTask( ), initOnce( ), ... Andrew Johnson
ANJ, 10 Jan 2013 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
· EPICSv4 · IRMIS · Talk · Bugs · Documents · Links · Licensing ·
