g+
g+ Communities
Argonne National Laboratory
1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013 Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013
Subject: Re: Extensions installation for newbie
To: EPICS Tech-Talk <tech-talk@aps.anl.gov>
Date: Thu, 10 Jan 2013 13:32:35 +0100
Sorry, I was wrong.
Somewhere is a ".." too many.
In general, the following should work:
Create a new dir, cd into it
Unpack extensionsTop_20120904.tar.gz
cd extensions
Set configure/RELEASE to
   EPICS_EXTENSIONS=$(TOP)
   EPICS_BASE=<wherever_your_base_is>
make
Good luck!
~Ralph
On 10.01.2013 12:32, Ralph Lange wrote:
Hi Mike,
you seem to be using an EPICS 3.13 extension tree, trying to compile against a 3.14 base.
Please start with an extension configuration that matches you base version.
The EPICS Extension page [1] has tars for both.
Good luck!
~Ralph
[1] http://www.aps.anl.gov/epics/extensions/index.php
On 10.01.2013 12:25, Michal Vítek wrote:
Hello,
I am new to epics and Linux and I am trying to install the Epics base with some extensions (MEDM, asynDriver, and stripTool). The base installation went fine, but now  I am having a problem during „make“ of the extensions. I think it is related to the files that needs to be modified, so far I have changed 2 (make file in the extensions top directory and RELEASE file of the extensions). Could somebody tell me what am I doing wrong ?
Cheers, Mike
OS: Scientific Linux 6
Extensions Make file:
TOP = /opt/epics/extensions
include $(TOP)/configure/CONFIG
DIRS = $(wildcard configure src)
include $(TOP)/configure/RULES_TOP
Extensions Release file:
EPICS_BASE=/opt/epics/base
EPICS_EXTENSIONS=/opt/epics/extensions
Log from make:
make -C ./configure install
make[1]: Entering directory `/opt/epics/extensions/configure'
make -C O.linux-x86_64 -f ../Makefile TOP=/opt/epics/extensions/.. T_A=linux-x86_64 install
make[2]: Entering directory `/opt/epics/extensions/configure/O.linux-x86_64'
../Makefile:5: /opt/epics/extensions/../configure/CONFIG: No such file or directory
../Makefile:9: /opt/epics/extensions/../configure/RULES: No such file or directory
make[2]: *** No rule to make target `/opt/epics/extensions/../configure/RULES'.  Stop.
make[2]: Leaving directory `/opt/epics/extensions/configure/O.linux-x86_64'
make[1]: *** [install.linux-x86_64] Error 2
make[1]: Leaving directory `/opt/epics/extensions/configure'
make: *** [configure.install] Error 2
Extensions installation for newbie Michal Vítek
Re: Extensions installation for newbie Ralph Lange
Prev: Re: routing Ralph Lange
Next: Re: routing Pavel Maslov
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013
Prev: Re: Extensions installation for newbie Ralph Lange
Next: dbScan.c: periodicTask( ), initOnce( ), ... Jack Smith
ANJ, 10 Jan 2013 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
· EPICSv4 · IRMIS · Talk · Bugs · Documents · Links · Licensing ·
