g+
g+ Communities
Argonne National Laboratory
1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013 Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013
Subject: Re: What's calling get_array_info?
To: mdavidsaver@bnl.gov
Cc: tech-talk@aps.anl.gov
Date: Wed, 9 Jan 2013 11:48:14 -0600 (CST)
Overwriting pfield does cause problems.  When you post the array, you have to post all three pfield addresses, because you can't know which was in use at the time a client connected.  (As you know, clients actually connect to array addresses, not to fields.) There are three pfield addresses, because buffers are not allocated until a detector field is first used, so the first address is the null array, and the other two are the actual data buffers.  The posting only alerts clients that new data is available; the real buffer address isn't specified until the client calls get_array_info().  It's awkward and unsatisfying, but it works.
Tim
To: "Ned Arnold" <nda@aps.anl.gov>
Sent: Wednesday, January 9, 2013 11:02:49 AM
On 1/9/2013 11:57 AM, Ned Arnold wrote:
The sscan record in synapps does that ... if you are looking for an example.  It "double buffers" the collected data allowing a client more time to access it.
From sscanRecord.c:
if (precPvt->validBuf == B_BUFFER) {
      paddr->pfield = precPvt->detBufPtr[group].pBufB;
} else {
      paddr->pfield = precPvt->detBufPtr[group].pBufA;
Well how about that.  This is just what I was thinking.  I had assumed that simply overwriting pfield would cause problems.  I'll definitely take a close look at this code.
Michael
Tim Mooney (mooney@aps.anl.gov) (630)252-5417
Software Services Group (www.aps.anl.gov)
Advanced Photon Source, Argonne National Lab
Re: What's calling get_array_info? Michael Davidsaver
Prev: Re: What's calling get_array_info? Michael Davidsaver
Next: Re: time drift in camonitor timestamps Jack Smith
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013
Next: Re: What's calling get_array_info? Michael Davidsaver
ANJ, 09 Jan 2013 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
· EPICSv4 · IRMIS · Talk · Bugs · Documents · Links · Licensing ·
