g+
g+ Communities
Argonne National Laboratory
1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013 Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013
Subject: Re: .PACT .TIME
To: tech-talk@aps.anl.gov
Date: Mon, 7 Jan 2013 09:56:50 -0600
Hi Benjamin,
On 2012-12-18 Benjamin Franksen wrote:
> On Wednesday, December 12, 2012 14:16:12 Mark Rivers wrote:
> > I don't think that PACT would really be considered "metadata".
> > But this Web page explains which fields in dbCommon do post monitors
> > https://wiki-ext.aps.anl.gov/epics/index.php/RRM_3-14_dbCommon
> Posting monitors for PACT would be a most welcome addition. Maybe this
> could be added in 3.15?
That would require changes to every record type's process() routine [which I
couldn't do for record types not in Base], and would hit performance.  Every
call to db_post_event() requires it to search the record's list of CA clients,
comparing the posted address with that of the subscribed field for every
subscriber, and for PACT there would be two calls since it changes twice per
process.
It /might/ be possible to make the .TIME field accessible over CA and post
monitors on it from within recGblGetTimeStamp(), but I haven't looked at the
code changes necessary to implement that.  The native type of the TIME field
would probably become ULONG[2] but I'd like to make it accessible as a string
as well, and doing all that might need some deep changes so no promises.
- Andrew
There is no such thing as a free lunch.  When invited for lunch,
it is best to check if you are there to eat, or to be eaten.
-- Clive Robinson
Re: .PACT .TIME Benjamin Franksen
Prev: Re: epics input and output via records Wesley Moore
Next: Re: epics input and output via records James F Ross
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013
Prev: Re: .PACT .TIME Benjamin Franksen
Next: unable to see epics variables James F Ross
ANJ, 09 Jan 2013 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
· EPICSv4 · IRMIS · Talk · Bugs · Documents · Links · Licensing ·
